Can DT Swiss 370 hu...
[Closed] Can DT Swiss 370 hubs be upgraded?
9 Users
Hi I’ve got some M1900 wheels, I’m thinking about buying another set of wheels to run XC tyres on as I live in the MTB Mecca that is East Anglia.
I was going to buy the XR 1700 and put the internals inside the M 1900 for more engagement on rocky climbs.
Alternatively they appear to sell upgrade kits.
Is this possible or not?
Posted : 14/11/2020 10:48 am
It's possible with the right tools. Check out YouTube.
Posted : 14/11/2020 10:50 am
Not really but apart from POE why bother?
They are perfectly good .. I'd buy 350's out of preference but nothing bad about 370's really.
Posted : 14/11/2020 10:51 am
As @scotroutes said, you can, apparently:
Looks like a few special tools are needed though.
Posted : 14/11/2020 11:04 am
Whilst it will 'work' the interface between the hub shell and freehub on the pawl and ratchet hubs is different.
You will therefore effectively have a gap that means there is no sealing and the freehub mechanism is open to the elements.
It may work for a while, but its not a reliable or long term solution, it will also comprehensively nuke your warranty, if you have one.
Posted : 14/11/2020 11:20 am
As per hatter ...
and the 370's are really not bad anyway... my 6yr old ones needed a new pawl spring but otherwise trouble free
I'd really need to think before sticking the ratchet in and letting in mud and water.
Posted : 14/11/2020 11:34 am
Thanks guys. So you can upgrade 350 to 240 internals but not really the 370 as it uses pawls.
I don’t mind the wheels they came on the bike but I have need better engagement on tech climbs a few times. Partly rider error.
The rims are very good absolute doddle to set up tubeless.
Posted : 14/11/2020 11:39 am
Yeah you end up with no sealing as above. So it’d be a no from me.
I just built a mates bike with dt350 hubs and XM481 rims. The hubs appear to have the 18t star ratchet which is quite slow vs my Hope hubs and it’s really really quiet. I don’t like them - my 370’s on the e1900’s made a better noise than the star ratchet. I can’t say I noticed any improvement on tech climbs from a quicker engaging hub going from 370 to Pro4.
Posted : 14/11/2020 11:55 am
You can feel the difference but I'd say it's 90% in your head as to the climbs... I'm not knocking that... I'm just saying if you worry about it then it deffo will affect you.
It 100% doesn't sound as cool .... 😉
Best bike analogy is like if you use clips and switch to flats...
Having my foot mm of difference screwed me up for ages... it just felt wrong. Then I convinced myself it didn't matter... after sending a few features I totally convinced myself ...
It might not be ideal but its certainly better than messing about as you approach a feature....especially if its something you stopped to check out...
Engagement is a bit like that (IMHO)... the more you worry about it the more it affects you.... so even when it "could be better" a bit of timing will sort you out.
Posted : 14/11/2020 12:08 pm
The noise on the 350s will get louder. I have the upgraded ratchet on 240s and they’ve got louder over time, very buzzy now.
Posted : 14/11/2020 12:11 pm
Time for a service (regrease).
It is possible to fettle the seal to make it work. Probably not winter slop and hose pipe safe though.
Posted : 14/11/2020 2:58 pm
joebristol
I just built a mates bike with dt350 hubs and XM481 rims. The hubs appear to have the 18t star ratchet which is quite slow vs my Hope hubs and it’s really really quiet. I don’t like them – my 370’s on the e1900’s made a better noise than the star ratchet. I can’t say I noticed any improvement on tech climbs from a quicker engaging hub going from 370 to Pro4.
It's what you'd expect with the 18t, 20 degrees between engagement, quite a lot, 36t is best for strength/engagement, i have 36t on one and 54t on the other, and they feel the same, but both are a lot better than the standard 18t!
Posted : 14/11/2020 3:30 pm
