can anyone recommen...
[Closed] can anyone recommend me a cheap slack hardtail frame for my rockshox totems...
Patriot too similar to my alpine now, so thinking of having a hardtail for a change, gonna sell the patriot and buy or swap for a hardtail frame, but it needs to be a frame that will take totems I have already, sub zeros seem good geometry but hard to get hold of, them on one's look alright too but not sure they can take 180 forks? Any other suggestions? Cheers.
Posted : 09/09/2013 11:36 am
Can you space Totems down? Not that many 180mm hts, for good reason, might make more sense.
Posted : 09/09/2013 11:40 am
Flog the Totems and get something more suitable. 180mm travel on a hardtail would be horrific.
Posted : 09/09/2013 11:41 am
Yeah I know what your both saying, just was gonna keep the totems to put on the alpine for when we go over to the alps, make it mega burly! ๐Ÿ˜›
Cheers anyhow.
Posted : 09/09/2013 12:03 pm
 IA
Solo air totems are easily spaced down, same spacers as other RS.
Posted : 09/09/2013 12:06 pm
180mm forks on a hardtail? That'll be horrible.
If you can space them down to 160mm (or ideally less than 150mm) then you've got a lot of options. Otherwise I'd just forget the idea.
Posted : 09/09/2013 12:13 pm
Evil Imperial..if you can find one.
Posted : 09/09/2013 12:21 pm
[url= http://www.darksidezoo.com/en/war08.html ]Darkside War[/url] - again finding one could be an issue
Posted : 09/09/2013 12:35 pm
Hmmm.. yeah maybe it's a bad idea, might just swap frame and go all rigid, can you get long rigid forks that will keep the geometry slackish? Could then use it as a winter trail bike. Cheers.
Posted : 09/09/2013 12:41 pm
 wors
I have a well used MK1 blue pig hanging in the garage doing nothing if that floats yer boat.
Posted : 09/09/2013 12:56 pm
 st
As above, space down the Totems to whatever you want with enought spacers I think.
Alternatively get some 29er rigid forks if you want to keep the front end up and go rigid for the winter.
Posted : 09/09/2013 1:03 pm
Summer season + a 445mm A-C rigid fork and a big front tyre. That'd be slackish and geo wouldn't change as there's no change in fork travel
Posted : 09/09/2013 1:05 pm
What forks do you have on the Alpine - could you use those on the hardtail and put the Totems on the Alpine.
As above first choice is run the Totems at 160 via spacers (or more sag ?)
Posted : 09/09/2013 1:06 pm
Yeah good idea jambalaya, but probably be too much of a beast for me to ride around here ๐Ÿ˜†
Cheers though.
woody2000 - Member
POSTED 41 MINUTES AGO # REPORT-POST
I think this is just what I'm after! Cheers.
wors - Member
It does float me boat, ๐Ÿ˜€
What size is it wors? Cheers.
Posted : 09/09/2013 1:58 pm
 wors
18"
Posted : 09/09/2013 2:03 pm
 gazc
dmr exalt in classifieds takes long travel
Posted : 09/09/2013 2:06 pm
Ns Surge is designed for up to 180mm forks. If you fancied selling the Totems I'm after a pair ๐Ÿ™‚
Posted : 09/09/2013 7:14 pm
