Campagnolo 10 speed...
[Closed] Campagnolo 10 speed chain - alternatives?
11 Users
Morning all
My 10 speed Campagnolo Veloce chain is getting near to the point where it needs to be replaced.
Is anyone on here running a Campagnolo groupset with a less expensive chain from a different manufacturer?
Will I regret trying to save a few quid?
Ta in advance.
Posted : 02/12/2020 8:57 am
I’ve always used KMC. You don’t need a special tool to join the chain together again either.
Posted : 02/12/2020 9:01 am
I would not change from Campa to KMC. All my chains are Campa, 9, 10 and 11 speed.
But I'm using KMC/YBN quick links to make my life easier.
Cheers!
I.
Posted : 02/12/2020 9:13 am
Why not?
Posted : 02/12/2020 9:15 am
 Jerm
I use KMC with no issues at all.
Posted : 02/12/2020 9:29 am
I use a Campag chain with KMC link. Although I've changed the link more than once because it's gone a bit sloppy.
The first time I looked I thought I'd got a Shimano 105 chain, but on inspection it said 10 S.
Posted : 02/12/2020 9:38 am
Why not?
Got better millage out of Campa than KMC.
Cheers!
I.
Posted : 02/12/2020 10:50 am
Another happy KMC user here
Posted : 02/12/2020 2:53 pm
Cheers all.
I've just had a look and over the years (10 or so) my Veloce groupset has been replaced with:
- Miche cassette (so I could use a set of Mavic wheels with a shimano free hub body)
- TA Chainrings
- BBB Jockey wheels.
Seems little point in splashing out on another Campagnolo chain!
Posted : 02/12/2020 3:05 pm
KMC or Sram on my Campag 10 speed always. Get yourself a chain checker and change it when it reaches the minimum wear point. You should get three chains to one cassette.
Usually use sram, campag chains are a pain, kmc quick links on a campag chain though. I use Kmc chains too, all good. I have campag on all my road bikes.
Posted : 02/12/2020 9:37 pm
 ctk
I used a Mavic chain when I ran Campag 10 speed. Still some around at £25ish
https://sprockets.uk.com/chains-10-speed/
Posted : 02/12/2020 10:02 pm
 keir
15000+ all weather miles with kmc x10.73 chains on Campag veloce. My go-to 10 speed chain.
Posted : 03/12/2020 8:29 am
