Camelbak insulated ...
[Closed] Camelbak insulated bottles - do they work?
8 Users
Looking for something to keep drinks warm in this cold weather... do the Camelbak bottles do the job?
Otherwise the Elite Nanogelite looks like the alternative option:
http://www.chainreactioncycles.com/elite-nanogelite-corsa-thermal-water-bottle/rp-prod89891?utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom&gs=1&gclid=CJmliqrCw8MCFUWWtAodhHMA1A&gclsrc=aw.ds
Ta.
Posted : 02/02/2015 5:35 pm
not for long (warm contents in cold air anyway) but better than nothing I think
Posted : 02/02/2015 5:37 pm
Hip flask with something strong for the ride 😉 and a vacuum flask in the car with some hot beverage post ride 😀
Or just ride harder 😛
More seriously, I find camelbak and the like bladders in a backpack tend to keep temperature a bit. Not tried hot things though, but I do find liquids in there don't freeze in sub zero (except in the tube, but there are ways around that), and in hot summer a chilled drink stays chilled for ages. Guess depends on the padding of the backpack.
Posted : 02/02/2015 5:51 pm
The smaller size insulated[url= http://www.kleankanteen.com/collections/bottles/products/vacuum-insulated-12oz ] Kleen Kanteen[/url] fits in a bottle cage and is a bona fide insulated bottle and a reasonably light one, but I guess it depends on whether you're after a vacuum flask-type thing or just a lightly insulated water bottle. I've not found the Camelbak one to do much at all.
Posted : 02/02/2015 5:56 pm
Blow back into the tube after each slurp so there's only air and no water to freeze. Or just slurp little and often.
I'm intrigued by a bottle cage flask though.
Posted : 02/02/2015 6:02 pm
I've got Elite one. It doesn't really keep things very warm, but it stops things freezing, which was the main reason I bought it.
Posted : 02/02/2015 6:04 pm
I find the Camelbak insulated bottles work quite well. If you start off with hot water, it will be warmish about an hour later (in cold weather).
Definitely warmer than a normal bottle, but nothing like a proper flask.
Posted : 02/02/2015 6:13 pm
Camelbak Podium [b]Chill[/b], will keep a hot drink fairly warm for about an hour in single digit temperatures. Boiling to stone cold takes 1 1/2 - 2 hours. There is also a Camelbak Podium [b]Ice[/b], which I haven't tried, but Camelbak (and a review) say is four times more effective, so keeps drinks warm for around 4 hours.
Posted : 02/02/2015 6:59 pm
