C-clips, where to b...
[Closed] C-clips, where to buy
 PJay
Where can I buy some of those useful little plastic C-clips for fixing brake hose to hose guides (much nicer than zip ties)?
I'm sure I saw some on CRC, but they seem to have disappeared. I can source some Jagwire ones off of ebay from abroad but presumably they'd be cheaper bought in the UK.
Posted : 26/10/2010 2:51 pm
Cable Ties.
You know it makes sense.
Do you mean P-clips?
Posted : 26/10/2010 3:15 pm
Cable ties. Or I (just this lunchtime) bought a packet in Halfrauds in the bike section. They have small packets of tat for about £2, including bolts made of cheese and C clips.
Posted : 26/10/2010 3:16 pm
i just bought some nice red ones from some foreign country seller off ebay
Posted : 26/10/2010 3:19 pm
email me - i have some you can have FOC if you send me an envelope
Posted : 26/10/2010 3:41 pm
the place in this thread has them £3 something for 4
http://www.singletrackworld.com/forum/topic/anyone-ordered-from
Posted : 26/10/2010 4:48 pm
Cable ties can be neat...
Posted : 26/10/2010 5:14 pm
3 Fish help us understand that pic, and the way you have used the cable tie there - please- cheers R
Posted : 26/10/2010 5:25 pm
@Lionheart
It is quite simple by the look of it.
You will need:
1 Cable Tie
A 5-10mm piece of rubber hose.
Take the cable tie and push one end through a bit of plastic tubing and around the brake hose.
Thread the other end of the tie around through the 5-10mm piece of rubber hose.
Cable tie around fork leg/brace etc as usual.
Posted : 26/10/2010 5:29 pm
 PJay
I did spot the colourful metal ones on ebay, they're produced by MOWA bikes in Sweden although the seller is in Hong Kong. I might try some.
Precisely as you describe. With some careful manipulation the grip part of the tie can be positioned wherever it is most discrete.
Posted : 26/10/2010 5:42 pm
Incidentally, where did you get the clear hose from Three_Fish?
Posted : 26/10/2010 5:57 pm
B&Q do it by the metre in the rope/tube/chain section. Around 80p/metre, if I remember correctly.
Posted : 26/10/2010 6:09 pm
Or instead of using the clear hose you can use the lockring off a presta valve.
Posted : 26/10/2010 6:47 pm
