Buying a single rin...
[Closed] Buying a single ring NW - do i need special bolts?
Seeing single ring specific crank bolts available...do i need these as they look to be about £13 quid for 4 small bolts ?
likewise do i need thoses tab shims or are the just for neatness? ie...
[url= http://www.wiggle.co.uk/ethirteen-chainring-tab-shims-pack-of-4/ ]tabs[/url]
FYI crank is 4 bolt sram x9 with an e13 30 tooth ring
ta
Posted : 19/01/2015 4:59 pm
moove do them cheaper with free post
Posted : 19/01/2015 5:02 pm
You can usually just flip the back of the bolts around, this will allow them to tighten down on the chainring. Obviously looks a bit shonky but it does the job at a pinch.
Posted : 19/01/2015 5:10 pm
 cp
[url= http://www.evanscycles.com/products/id/single-chain-ring-bolts-ec006126 ]a fiver for silver ones[/url]
Posted : 19/01/2015 5:18 pm
search ebay for "singlespeed chainring bolts", there's tons and tons starting at about a fiver for 5. all colours, Ti ones for around a tenner a set too.
Posted : 19/01/2015 5:21 pm
thanks folks...do i need those tabs as well?
Posted : 19/01/2015 5:23 pm
Unless...you're buying a 30T ring that is actually threaded, you can just use the existing bolts, well half of them.
Posted : 19/01/2015 5:24 pm
You would use either the tabs or the bolts I think.
Posted : 19/01/2015 5:29 pm
No, either shorter bolts OR shims.
EDIT: Damn, too slow.
 Yak
e13 30 tooth ring
don't know about that ring, but the on-one ringmaster nw ring was so thick that regular bolts fitted perfectly.
Unless you are in a hurry, get the ring then try regular bolts (the right way round) and if they are too big, then get some specific single ring bolts.
Posted : 19/01/2015 5:38 pm
