Buying a middleburn...
[Closed] Buying a middleburn UNO crank do I get Isis or square taper ?
[#4817746]
After much thought n reading up on threads I have decided to go with a new middleburn UNO crankset for my SS build. I havnt used square taper for a long time as my last few cranks have been X- type. Is this a problem as far as reliability and weight when looking for a BB . Or is it better to go Isis version though I've heard a few problems with that type of bb. The rx-8 type UNO looks nice but is alot more ££ so its square taper or Isis ?
Anyone who could help put my mind at a ease before I purchase ?cheers
Sorry I posted this in chat section by mistake for those who have read it already.
Posted : 31/01/2013 8:54 am
Phil Wood (or similar) ST BB. [b]I[/b]s[b]S[/b]hite[b]I[/b]s[b]S[/b]hite is shite. (i have ISIS, ST & them external thingeys)
Posted : 31/01/2013 9:05 am
I keep hearing this ISIS is rubbish thing and wonder why mine works just fine...
Rachel
Posted : 31/01/2013 9:07 am
 Joe
You're obviously not fat enough Rachel. ISIS BB's disintegrate.
Posted : 31/01/2013 9:08 am
Best ISIS by STW review is Superstar Components, I have 2 Race Face signature ISIS BBs and the tools to service them, they last a lot longer if you pop new bearings seals and fill with a quality grease, though they so develop play or go notchy before any ST I've ever owned.
Posted : 31/01/2013 9:11 am
PS: IIRC ISIS is the stiffist and is / was the BB of choice for DHers, but things have probably since changed.
Posted : 31/01/2013 9:13 am
Or seek out a SKF ISIS BB stash from some dark corner of the internerd.
Posted : 31/01/2013 9:15 am
I wish that was true, Joe!!
Posted : 31/01/2013 9:31 am
I have RS7's with a Superstar ISIS bottom bracket and the last one lasted two years which I was happy with compared to 11 months for SKF and no more than 4 months for Raceface or FSA.
The Superstar ones are great and only £30 you can't go wrong.
Posted : 31/01/2013 9:45 am
I'd go for Square Taper for greater longevity of the bottom bracket. The UNO is a nice system although they don't do a steel chainring (yes you can get a spider for your own ring but I've broken two of those). Some people find that the Middleburn tapers are a bit soft, so go easy when you tighten them. They're quite good with warranties though.
Posted : 31/01/2013 9:57 am
Is there much weight difference in the Isis bb compaired to the taper ?
Posted : 31/01/2013 10:09 am
I've got a variety of BBs. On the road I'm still using an ergomo power meter that uses isis (my versions anyway) bottom bracket sensors. I also had a middleburn chainset with skf isis bottom bracket. As long as you find a quality bottom bracket (and the SKF one is in my experience) there is no reason why it shouldn't last - its the quality of the bearing not the shape ofthe interface that matters. My issue with the middleburn/skf setup was the creaking - drove me potty. In the end I got rid of the lot - no idea which bit was at fault but countless strips and refittings never sorted the issue.
Isis and octalink have had their day imo - its all about the various external setups now. The only "old skool" set-up with a continued niche following is square taper so that's the way I'd go in your position.
Posted : 31/01/2013 10:11 am
Cheers Simon I think its a toss up between the rs8 x-type at 220 but seems to come with 9 speed chain ring ? Or the rs7 square taper with hard coat ring for £128 mmmm
Posted : 31/01/2013 10:12 am
Cheers convert 🙂
Posted : 31/01/2013 10:21 am
