Bugger. How to get ...
[Closed] Bugger. How to get rebound switch back onto a fox shock?
Stripped shock for a service and whilst at it i thought i'd strip the rebound knob down as it was full of grit.
Should have googled first.... Didn't realize there would be a sprung bar in there.
I can't get the switch back on as the sprung bar for the rebound adjustment gets in the way. Those in the know is there anyway of reassembling it without sending it away?
Posted : 18/08/2013 11:21 pm
Uh-Oh! Its a send-it-off job :-/
Mojo, TF, etc
There's no way you can get this back together now as the mitre rod from inside the steel shock shaft has to be fitted *after* the rebound dial
Posted : 18/08/2013 11:59 pm
I did the same (although I did Google first I didn't find anything). Sent it to Mojo, noting I'd already replaced the seals. They said seals were damaged, shaft scratched, and replaced them. Not cheap, but much cheaper than a new shock.
Posted : 19/08/2013 6:48 am
Bugger. Looks like loco will be getting a call then, was kinda hoping there would be some magic trick to sort it.
Posted : 19/08/2013 8:22 am
 LoCo
Re gas and re oil to rebuild I'm afraid or full service if due, will be in about 0930 ish as out doing errands ATM.
Posted : 19/08/2013 8:46 am
I had the same problem-Don't send to TF as they ended up sending it onto mojo anyway adding a week onto turnaround.
Posted : 19/08/2013 9:53 am
Ah well, looks like I can at least take solace in the fact i'm not alone!
Cheers guys.
Posted : 19/08/2013 5:41 pm
