As far as I can tell there has always been bubbles in my pee, more so in the morning, had assumed they were just from the pee hitting the toilet water. Came across an article a couple of days ago however that says bubbly pee is a sign of protein in urine, a sign of kidney disease.
I got hold of some urine dip sticks and they aren’t positive for protein (no idea how accurate they are but Ive done them for 3 days straight ), and my blood kidney test back in March was fine
For clarity, there are quite a lot of bubbles (almost frothy at times ) however they begin to disappear quite quickly, but a few do remain around the edge of bowl if I don’t flush
Seems like a ridiculous thing to bother my GP about, especially if it’s completely normal but Dr google has me concerned
Are you honestly asking a bike forum this question? Go to see your GP, is it really worth risking?
Don't see a problem with asking - op only wants to know what other peoples normal looks like, it's surely preferable to taking a long look as someone is taking a wizz in the urinal next to you. FWIW - no bubbles here.
How does it taste compared to other people's?
If it’s fizzy I’d be considering mouthfeel rather than taste.
… however for the OP I can say my pee bubble levels are more southern real ale than lager.
How does it taste compared to other people’s?
Posher, clearly, its carbonated.
Go and see a GP OP.
I asked this same question many years ago on here. I went to the doc, they checked me out, couldn't find anything wrong. It's less bubbly now though. Dunno why.
This sort of thing annoys me. In fact it really boils my...
i would say that in the absence of protein in your urine dip (the thing a GP would test for) there's probably not much more to do in teh absence of other symptoms (recurrent bladder infections etc)
DrPee
Never even knew this was a thing!
OP i am not a Dr but i would go and see my GP if i was worried.
Part of me thinks it may be a hard water/soft water in your cistern thing?
Ian
+1... STW a learning experience, admitted not necessarily a useful learning experience
Mine can look like a frothy Fanta at times! Quickly goes away though, can be fun when at a trough urinal and someone is downhill. It's the same reaction from them as when you pee in those blue blocks and the resultant flow takes on a nuclear colour (especially if you've been on the Berrocca tablets!), they are concerned but urinal etiquette says never talk to someone while in attendance so they just try to ignore it while trying to hide the fact they're wanting to get out of there asap 😆
If it's Ike it all the time go see a doctor, if it goes away in a day or two you've probably just ate something odd.
OK, technically there's a difference between 'frothy pee', and bubbles in pee...
it seems you really mean frothy pee, right?
In the absence of protein, it's likely just a combination of the toilet water and something you've eaten.. I get it a lot!
DrP
Thanks all and assuming Dr P is an actual doctor then that’s reassuring
I’m going to assume you’d need quite a lot of protein to cause frothing and given numerous dipstick tests are negative I think that’s unlikely, unless I have a dud batch. Also, my egfr was 100 in March, so that’s reassuring as well
To be prudent however I’ll drop a line to the GP. I’m assuming they will laugh me out the door but better safe than sorry I guess.
OK, technically there’s a difference between ‘frothy pee’, and bubbles in pee
Tbh I’d describe it as quite frothy although it quickly disappears and leaves a few bubbles round the edge of the pan. It’s not like that nasty foam that you see on the beach or anything like that!
Dr P … seems appropriate
How tall are you OP?! If it’s landing from a great height that might be the reason. Try crouching if over 6’5”.
In all seriousness though, go to your GP if concerned.
I'm reminded of a teaboy on a construction site I was on on pouring tea into the site engineer's mug from a great height 'cos he hated frothy tea.
I don't understand how you can tell if your pee is bubbly as opposed to the water in the bowl. Mrs. Slow suggests weeing slowly into a container close to your willy to see if it's still bubbly.
Do you have a cold?
I was once told that pee was more frothy due to the mucus. Not really sure how it would work. Do kidneys and bladders produce mucus?
First thing in the morning game for me is....see if I can fill the bowl with frothy bubbles. I have kidneys, probably about the only thing left of me that functions okay. As with everything though, if it worries you, even the slightest wee bit, go see your GP.
Very good.
Surely the OPs height is only one of two factors in how far his pee drops to the water? 😉
This is a blatant attempt to win thread of the week on FGF and I salute it
This is a blatant attempt to win thread of the week on FGF and I salute it.
I find mine is more bubbly when there's one of those cleaning tablets sitting in the cistern.
Are you sure no one's snuck one in, purely to mess with your mind?
It's more obvious when it's the blue type... unless your pee is normally blue?
We need to determine whether it is frothy (bubbles on impact) or fizzy (bubbles on release).
Is the second his inside leg?
Or the step ladder he climbs on to pee. (Don't ask about what he climbs on for poos...)
Wee in a pint glass? Check it it actually has bubbles?
Dr. Google suggests that:
"bubbles in urine is quite normal and should disapear after 10-20 minutes."
Are you waiting this time studing your urine in the toilet? Otherwise,
"bubbles when collected in sample form are a sign of protein in the urine and should be checked out by a medical professional"
Are you collecting your pee in sample format, or just urinating in the toilet?
The general advice is to go see a GP if you're worried, but I also think googling conditions can easily make you worried.
This sort of thing annoys me. In fact it really boils my…
Deserved recognition
I think your partner is putting some fairy liquid in the bowl and playing a long game prank on you! Have you upset them recently?
I have an appointment with the doc tomorrow and a small beaker to piss into
Must say I never thought of seeing if it bubbles in the container. I don’t think it does tbh!! Should have paid more attention
Again, I’ve never left it so long to check!the doc is going to laugh me out the surgery aren’t they!😩
Re height..5.10. Short legs, combined with average boabie shouldn’t be causing the issue…
I do have magnificent balls however… doubt that’s a factor but I like to mention it…
Even when I'm really burstin' I can't pee for that long.
(Don’t ask about what he climbs on for poos…)
A stool surely?
A stool surely?
very good. 👏
I would think so, but I've now got a visual picture of them floating through the air.
Think of it like head on a beer vs head on a coke. If it stays for 10 mins and would pass at Oktoberfest, see a doc.
Foamy wee is actually a really insensitive sign and urine dipsticks are far more sensitive for low levels of proteinuria.
I am a doctor, but only on the internet and I don’t profess to be a professor of foamy wee-ology.
It’s definitely more coke than octoberfest pint.
Good to hear dip sticks are reasonably sensitive. I’ve used 4 of them and all negative. Doc has told me to take a piss in a tub and bring it along tomorrow, I’m assuming they’ll send it away for analysis rather than just use a dip stick but we’ll see. I also have a lovely pic of the contents of my toilet to show him.
Where are you supposed to insert the dipstick?
Hold on. Are you using any sort of toilet cleaner, detergent block or bleach? Any liquid hitting another with soapy stuff in it will cause bubbles.
try pissing in milk bottle of something like that.
Measuring jug. Might as well estimate flow rate and volume at the same time 😉
For my Chris Froome defence, I measured urine output for a week. You make about 0.5 to 1 mL/kg/hr if you are interested. Much less when exercising (down to zero in fact).
This came up at work a few years ago, someone saying it was a sign of something serious. Someone else that might have been me started putting a few drops of washing up liquid in the toilet.
I went to the doc for this exact thing and the first thing she did was put a dipstick in it. The sample, I mean.
