Bristol plans devel...
[Closed] Bristol plans development of the Timberland Trail etc
C'mon TooTall - raise a smile, IME, the new stuff is great on a 29er... surely that makes you happy ๐Ÿ˜€
Posted : 16/06/2011 10:20 am
Yes it needs work, but just don't smooth it over!
One point that has been missed is that the trails had to be built this way or we risked loosing them all together on environmental grounds. I love the new trails but even if I was luke warm, I'd prefer them to being outlawed from AC.
http://www.cyclistno1.co.uk/blog/bristol-trail-redevelopment-kicks-off.htm
Posted : 16/06/2011 10:31 am
Re the direction point, the new trails are being built to flow better in a certain direction. For example, the uphill arm of the quarry trail has shallower berms and wiggles about a lot more than it used to. The downhill arm has massive berms, direction specific features like rock steps, and a little hill at the start to launch you into the first section.
I'd expect some people to ride the wrong way initially out of curiosity, or for old time's sake, but if it's more fun the official way then that will be the way most people will ride.
Posted : 16/06/2011 10:38 am
The article says the risk was because the trails were getting wider (and encroaching on the orchids I've never noticed - will have a look for them next ride) - I'm not sure that that's really true - I've been riding them for 15+ years and the lines have certainly changed but fundamentally the trails went between certain trees and stayed there, not actually getting wider beyond that gap between the trees - eg they didn't encroach any more land.
Posted : 16/06/2011 10:40 am
Mr_A on direction, my understanding is that BBL is going to still be designated as uphill in which case people will always ride it the 'wrong' way as we have done for years after it was 'officially' made the wrong way with the advent of the TT.
Posted : 16/06/2011 10:41 am
Clubber are you for real?? I've been riding there the last 10 years and the quarry loop in particular has gotten pretty motorway-ish. And there were plenty of spots on Upper quarry where there were 3 lines around trees with a fourth developing. Same on BBL.
Posted : 16/06/2011 10:46 am
Mr Agreeable: If the direction issue isn't address, you may well end up with some public liability issues on your (I say yours, when I actually mean whoever is responsible) hands when someone clatters into someone else and then a smartarse lawyer picks up on it.
Adding to that, its bloody fustrating normally, but now its likely to be even worse, especially as the trail is 'thinner'
That artice that poster above linked to is very good - thanks!
Posted : 16/06/2011 10:47 am
BBL? (sorry, I've been riding them for years and never been told the names).
Posted : 16/06/2011 10:48 am
Well it's debateable ๐Ÿ™‚
I think you've misunderstood what I wrote or that I wasn't clear enough - I agree that the trail itself has widened but the area that it covers is bounded by certain trees and the trails don't go beyond them - so while lower quarry was say 1m wide originally, it was expanding up to 2 or 3m wide but still between those trees and so it wasn't getting wider beyond that eg it limited itself.
BBL = Beggar Bush Lane
Posted : 16/06/2011 10:50 am
Clubber raises a good point. If you are an old skool wheels on the ground sort of rider then some new techniques may have to be learned before you can rule the new trails.
Posted : 16/06/2011 11:03 am
Ok but the effect is still a widening and a lack of planning permission in a sensitive area, everything your typical anti-lobbyist needs! ๐Ÿ™‚
I'm a bit behind. Is everything open now? Might go out after lunch
Posted : 16/06/2011 11:11 am
Clubber, the trail was massively wide in places. The end of the open section by the eventing field for example. I haven't seen the reports that the ecologists prepared but apparently they were having kittens. We used to have to spend quite a lot of time at trail days just narrowing down the corridor and closing off the new lines made by people who couldn't be bothered to go round corners.
Posted : 16/06/2011 11:20 am
Neil did you even read what I wrote about direction above? In any event the direction issue has gone unaddressed for years and the estate haven't been deluged with liability claims.
Posted : 16/06/2011 11:24 am
I haven't ridden the new trails yet, only seen them as they were closed in prep for BBF.
When I stopped a few 3 lots of new/beginner riders asked me which bits were closed, so I got talking to them. Apparently they were quite worried about the riders coming head on, I told them people should soon be going the same way. I tried re-assure them that most mountain bikes have damn good brakes, one of the replies was "so why dont they use them then". They also were not sure if they were going the right way, they were.
I don't have much of a problem with people going the wrong way, as long as they acknowledge you've moved over for them. If it's now going to be one way, I won't be moving out the way for the muppets still going the wrong way, they can go the wrong way, they will just have to give way to all the traffic now.
Hope the rain holds off for 4pm tomorrow, so I can ride the AC trails, must try and find LH ๐Ÿ˜ณ
Posted : 16/06/2011 11:28 am
I did yes, and I do see what you're saying.
However Mr and Mrs Miggins and their young daughter may not - and may well be pretty aggrieved when someone rounds one of the faster sections.
By increasing the traffic and accessibility to Ashton Court there is a bigger breadth of responsibility - by building man made purpose built trails and, indeed, a trail centre cafe, [i]someone[/i] must be taking responsibility for the running and overseeing of the trails, and in turn they take on the public liability and H&S overhead. Look at what happened at Stil as an example.
Whereas before, all the trails were unofficial (to a degree) and they were VERY clearly ride at your own risk - which is very hard to enforce - and even harder when a trail becomes purpose built rather than naturally.
I'm happy with everybody using the trail - it's great - but I'd hate to start having people shouting at me for razzing down it the right way because of their own ignorance.
It has to be handled somehow - Cwmcarn/Afan doesn't suffer this because Mr and Mrs Miggins and their young daughter don't ever consider riding it!
I'm not getting funny with anyone in particular - but I know it confuses the hell out of me when I start seeing two way traffic - am I going the wrong way or are they? Or is it free for all now?
If it's free for all, then the speeds and visibility on the trail need to be considered as some nasty accidents could be occuring soon from some of the raceheads that have ALREADY decided that they're going to use the Qaurry track as their own personal training ground:
We rode there the other day and were astounded by the lad who, after putting his saddle down to hit the trail (by which time we'd just ridden ahead of him whilst he did that), he skidded to a halt at the end of the trail (ripping up the good work already done on the trail), triggered his stop watch and then did that 'Look at me, I'm cool, but I'm angry at myself that I didn't better my best time' shake of the head.
They, I'm sorry to say, are going to be the ones who clatter Mr and Mrs Miggins and their young daughter - not the majority of us here.
Posted : 16/06/2011 11:36 am
ETA also, Mr and Mrs Miggins and their young daughter don't read this forum. Nor will they likely bother to read any website info or whatever - so it needs to be trailside info IMHO.
Posted : 16/06/2011 11:37 am
The quarry trail is going to be knackered very very quickly by the muppets skid everywhere anyway, so I guess it will slow people down in the long run anyway. I saw one group who appeared to be seeing who could do the longest skid, at the end of the quarry section ๐Ÿ™
Perhaps a 'keep the skids in your trousers' poster/notice is needed at either end of the trail.
Posted : 16/06/2011 11:41 am
Nope. Quarry trails closed for repair of BBF wear and to change a few bits to sort the flow out. New Barn wood closed (both the new red trail and the old rocky section). Singletrack from bombhole by the monument to the quarry trails closed for trail to bed in.
Pretty sure BBL is still open, but most of the other stuff is not. Of course there's still d*ckheads riding it, using the "but they didn't consult [b][i]me[/i][/b]" argument (true story).
Posted : 16/06/2011 11:45 am
They're putting in new, clearer signage too. You seem to think that no-one has thought of these issues...
Posted : 16/06/2011 11:49 am
To be fair Mr Agreeable, that was all you had to say in the first place ๐Ÿ˜•
If that's the case, then great - if someone gets arsey, we can at least have some form of evidential way of saying "RTFM"
Posted : 16/06/2011 11:55 am
 SOAP
Are the trails fully open yet and Is there a map at the start of the trail
Think the last time I rode there I went the wrong way! Quarry on the right hand side slightly up hill.
Has anyone got a route/map/gps/picture linking AC , 50Acre and Leigh woods together ?
Posted : 16/06/2011 12:07 pm
GEOFF1, 3 posts above yours! ๐Ÿ˜‰
Posted : 16/06/2011 12:16 pm
For maps see www.bristoltrailsgroup.com. For news on closures and building, bookmark 1sw or Architrail on twitter. Easy!
Posted : 16/06/2011 12:25 pm
 SOAP
Cool but all the trail names mean nothing to a non local and I didn't see any signs before the work started.
So I'll wait a couple more weeks then?
Posted : 16/06/2011 12:26 pm
Work was supposed to be carried out March - June in AC, but didn't actually start until 3 May. I'd assume, therefore, that work won't be finished until August.
Posted : 16/06/2011 12:42 pm
Read this over quite a few times now and still keep coming back to the same things about Ashton Court as a whole and not just the bike trail.
There's concern over SSSI's and land that needs to be protected. I would love to see a map of the whole estate to actually find out where these places are as there are no signs/maps I can ever recall seeing (and I've been a regular visitor for getting on for 40 years - South Bristol lad me).
The powers that be were quite happy to cut down the big Redwoods in front of the house (aren't trees protected) because it suited them. Oh and it made the views better from the outdoor seating area from the new cafe.
New car park at the top of Kennel Lodge road - next to cafe.
New family cycle trail- accesible from top car park - next to new cafe.
If I was being cynical I'd suggest someone has thought about where a new revenue stream could be generated.
I really do hope that when the new trail has bedded in it becomes more interesting beacause after 11 laps at the bikefest I was properly bored of the twisty lower quarry trail.
I'm also aware that it couldn't continue as it was and I don't think you can praise the Bristol trails group enough for the work they've done but at least with the old muddy trails you had to think and pick a line.
Sorry rant over.
Posted : 16/06/2011 12:52 pm
The trails are going to be completed by the end of July, but will probably stay closed for a bit longer so they can bed in.
Geoff, the maps on our website use Google, so if you click 'show labels' and zoom out a bit you should be able to get an idea of where everything is.
Posted : 16/06/2011 1:00 pm
Racemonkey, have a look at www.natureonthemap.naturalEngland.org.uk.
Having a revenue stream from the new trails is definitely a big part of the plan. The way things were previously, the trail was dependent on volunteers fixing it for free, over and over again. The new trails aren't going to need as much maintenance and hopefully when they do there will be a proper budget in place.
Posted : 16/06/2011 1:13 pm
Well I like it. Give it a year or two to bed in a bit and it'll be ace.
The 'old' trails had all but diappeared under the relentless traffic anyway.
Still amused that a bunch of randoms on a forum are having to digest and regurgitate publically availible information for other lazier randoms.
Posted : 16/06/2011 1:20 pm
Rode the trail again last night on my way home and once I got to the Upper Quarry I was pleased to see that some needed tweaks to the trail have been put in place - closing off the straight lines that had appeared and sorting out the first 'hill' into it (leveling it out, as you fell into the fence if you weren't concentrating).
Top work whomever did that ๐Ÿ™‚
Although, it is disappointing to watch riders STILL riding around the closed sections and on the new unopened parts of the trail.
However, I like what I see in some parts of the new trails, but also am sad to see the really rooty rocky short DH section to the bottom of the Quarry has been smoothed over ๐Ÿ™
Posted : 17/06/2011 11:26 am
Nooooooooooooooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Why did they do that! it was on only remotely technical bit in there!
Posted : 17/06/2011 11:46 am
I have no idea - I agree with you - it was a hoot to ride down and I saw some awesome slams in front of me down it on the Sunday at Bikefest.
Posted : 17/06/2011 11:51 am
That is bad news, that section was excellent for making sure I had my forks set up right.
Posted : 17/06/2011 12:09 pm
 Leku
Quarry section shut this morning 'for maintenance'.
Posted : 17/06/2011 12:13 pm
At the end of the day AC has become f*cked over the years just simply because of the amount of riders. The quarry trail used to be sweat single track trail instead of the diveted mudfess it was, even with all the sterling work of the trail building group. Not only was AC generally crap to ride it was looking a bloody mess which must have just wound up the AC authorities. We now have a whole bunch of cash and a brand new trail that might not be to everyones liking but doesn't half sort out the long term issues (drainage, mud). Leigh Woods is in an even worse state and looks terrible (granted them chopping a whole load of trees down hasn't helped). Mountain biking is meant to be about getting one with nature not wrecking the place. Hopefully the new trail in LW will divert people off the old trails and let them repair.
My view is that mountain biking in AC and LW is not possible long term wise with such large numbers of riders without these new types of trail getting built. I think riders that remember the old days with lovely narrow single track just have to take off the rose tinted glasses and realise that its no more and AC was just trashed. I also have a massive respect for everyone that has organised these developments as even if you don't like the trail style at least they are getting off their arses and doing something about it.
Posted : 17/06/2011 12:52 pm
woody+1
Posted : 17/06/2011 12:55 pm
Well said that man.
Posted : 17/06/2011 1:47 pm
Woody...Thank you for prefectly summing up what i couldn't be bothered to type!!!
The negativity from some baffles me. Nothing in AC was remotely technical anyway IMO and all the really good stuff in LW will remain untouched so what's the problem.
In AC the council have an obligation to provide a trail that's fun and rideable for all, that's what's been achieved. If you don't like them, then go ride elsewhere. Simple as that.
Posted : 17/06/2011 7:34 pm
If the new trails aren't your cup of tea, there is nothing stopping us from building more technical trails elsewhere. We've got free rein with 50 Acre Wood, and we're also discussing another site with the powers that be.
The problem is that we're not going to get much done if people's attitude is to moan on the internet and wait for someone else to do it for them. Other branches of our sport like DH and dirt jumping have a very strong culture of "if you want to ride it, build it" but for some reason only a minority of XC riders make the connection.
On a lighter note, the Quarry Trails are already open again and should be bedded in nicely after all this rain.
Posted : 18/06/2011 11:37 am
I think i need have a little test run on the new quarry bit tomorrow. Other reports say a mixture of opinions but ashton court is going the right way of being open to everyone and that 50 acre/leigh woods could be a bit more developed for cyclists who want something more technical. I like your thought Mr Agreeable about 50 acre and the possibilities of another site for a trail or something and I would like to help out with that if it came to light
Posted : 18/06/2011 12:13 pm
Shame about that short downhill section, certainly was at least "remotely technical" if taken at speed. Not sure there was a need to smooth out that piece of trail, although I guess it is now more in keeping with the character of the other changes.
Posted : 18/06/2011 12:37 pm
It's easy to forget how stuff looks to learner riders. We were out recently in Ashton Court with a guy from the forum, and his girlfriend (who hasn't done that much riding) refused point blank to do that section. I would also be surprised if whatever replaces it is totally un-fun.
Posted : 18/06/2011 4:36 pm
Mr Agreeable, new area for development sounds exciting, where might that be? Always wondered why over the years no trails have been built to the south side of the lower quarry trail. Lovely bit of tapered hill side with loads of natural bomb holes, drop offs etc. A meandering cross hill trail, Afan esk, would be cool.
New trails actually look like they will be quite technical at high speed once they have bedded in and gone a bit back to nature. Give it a year and I think they will be sweet, right at our door and no need for the bridge toll for some cool riding!
Posted : 18/06/2011 6:21 pm
Woody, we were taking to them last year about "formalising" the trails in Ashton Hill Plantation (also known as Failand) and building some new sections to make a continuous singletrack loop. Unfortunately due to staff cutbacks and the Forestry Commission sell-off proposals they didn't feel that they could to commit to it. Things are looking up again given that the FC are no longer going to be privatised out of existence and we'll be talking to them in the near future.
It's one of the more environmentally sensitive bits of the estate - badget setts, 500 year old oak trees, etc - so building a trail through there is out unfortunately. They did try and put something in when designing the new trails but it wasn't a goer.
Posted : 19/06/2011 10:51 pm
Thought I'd give it a go this morning and I can report that the new trails are great on a CX bike ๐Ÿ™‚ Even managed some half decent pumping...
Posted : 20/06/2011 4:36 pm
 DJ
So, forgetting all the bickering, What has been completed so far and what do people make of the new parts?
Posted : 01/07/2011 10:24 am
Well it appears clubber can't stop and won't stop PUMPING!!!!!!!
Posted : 01/07/2011 10:28 am
Upper and lower quarry, the bombhole and deer fence section, New Barn Wood.
Summary of new parts: very different, very BMXy, very smooth (though the rooty DH which isn't open yet is now the rocky DH), very mud resistant, good fun.
Once you pump you can't stop!
Posted : 01/07/2011 10:32 am
 DJ
Just found this:
http://www.betterbybike.info/off-road-mountain-biking-route-announced-at-ashton-court
I hadn't realised the track along Beggar Bush Lane and down towards the gatehouse had been reversed! I always thought it was going to ride the same way round?!
Posted : 01/07/2011 11:20 am
Page 3 / 3
