Good news - I picked up one of the bargain brand x dropper posts in the crc fire sale.
Bad news - after a couple of weeks its failed.
It won't lock at all. As soon as you sit on the post it drops. But when you take your weight off it, it rises.
Problem happened quite suddenly during a ride
Definitely not an issue with the cable or the the actuation rod getting stuck - I didn't fancy risking a return to crc/evans/ashley so I've taken it apart to check.
Any suggestions for what might be going wrong??
It's not the cable being too tight is it ? Does it lock if the cable tension is released completely?
Make sure the cable isn't pulled through frame...it might not allow the cable to go far enough to lock the post...if it suddenly happened then likely the outer cable has been pulled and now stretched.
If it isn't that, check the inner cable isn't too tight and not going far enough to allow the lock to happen.
Thanks, but certainly not a problem with the cable getting stuck. I've taken it apart and disconnected the internal cable/cord. Still the same problem.
Whats obvious is that the brass keys are way smaller than they are on the other ascend posts I've got.
As you've already ruled out the cable and actuator, it sadly means the cartridge has failed prematurely. As these are fully sealed units there's nothing you can do to repair. It's not possible to open up the cartridge due to the rolled and crimped ends. There is no other option other than to source a new cartridge.
In light of the fact that Brand-X were owned by the Wiggle Chainreaction group, spares are currently unavailable. However, the Raceface Aeffect droppers are identical to the Brand-X Ascend and as such all spares are identical. The only constraint is that the Raceface Aeffect cartridges are only available for internally routed versions. They're also £70rrp due to the packaging saying Raceface vs the £30rrp for Brand-X packaging. The cartridges are identical though
@raceready Thanks, although not quite what I wanted to hear.
My post is externally routed so can't even use the race face spare.
It is... I'll pm you. Cheers !
Big thanks to race ready!!
Firstly for taking the time to respond, followed up with quick delivery and great price.
Thanks also to STW - without which none of this would be possible.
@racereadysuspension do you still have the other one? Today my externally routed 170mm Brand X Ascend XL suddenly developed the exact same problem. Would love to take it off your hands if it's still in stock.
ot enough air is often the issue - they need a certain amount of air pressure for the lock to work right.
And sometimes the actuator can foul on something in the frame (e.g. bottle boss in my case) and stick "open".
Exact same thing happened to me halfway through a race stage. Brand new dropper too. And I just sold my spare 😩
Had exact same recently, got new cartridge from https://ascendcomponents.com/
They were extremely helpful, making sure I got the correct cartridge for my external BrandX post. Easy to follow assembly instruction on their site too. Problem all sorted 🙂!
