Brakes for Kinesis ...
[Closed] Brakes for Kinesis T3 ?
Hi,
What brakes are people running on their T3s? I want to run 28s and guards. Will a stock 105 brake (which says it will take 28s) do? Or do I need something with wider clearance?
Thanks!
Posted : 28/12/2019 9:39 am
The frame is designed for a long drop brake
https://www.kinesisbikes.co.uk/Catalogue/Models/Racelight/T3
Posted : 28/12/2019 10:02 am
I used these on a T2 and they would tale a 28 without guards but I'm not certain about with them. Decent brake though
https://bike.shimano.com/en-EU/product/component/105-5800/BR-R650.html
There's not a lot of choice in long drop calipers, from what I remember Tektro and Miche were other options
Posted : 28/12/2019 10:33 am
Thanks, will have a look for some long-drops.
Any idea how long they need to be? IIUC the new 105s (7000) have a greater drop (51mm) than the older ones (49mm) not sure if that is enough, or if you really need the full 57mm ones?
Posted : 28/12/2019 6:54 pm
Kinesis say long drop / 57mm. Depending on your budget TRP RG957’s are very good but they’re around £100.
Posted : 28/12/2019 7:17 pm
I had a kinesis as a winter bike. IIRC I used Shimano R650, Ultegra level I think. I’d happily use R451 too, their calliper brakes are just fine.
Posted : 29/12/2019 12:57 am
 mboy
You NEED the 57mm drop I'm afraid. Shorter just won't reach properly.
Posted : 29/12/2019 1:43 am
Thanks all will do some research on those options.
Posted : 29/12/2019 6:09 pm
