Brake mount questio...
[Closed] Brake mount question for Avid Elixir
If i purchase an IS mount Elixir, and i also purchase this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=13717
would i be able to fit the brakes to my post mount fork?
Many thanx
Posted : 21/12/2011 7:04 pm
The elixir will go straight onto posts with a 160mm rotor, and will need a +20mm spacer for a 180mm disc. What size disc do you have/are you getting?
Simon
Posted : 21/12/2011 7:16 pm
I'm buying the Elixir in 185 front, so the spacer should already be there.
Posted : 21/12/2011 7:45 pm
Yup, the adaptor in your CRC link will work fine, just swap it with the supplied IS mount.
Simon
Posted : 21/12/2011 7:55 pm
Thanks Simon, much apprecited
Posted : 22/12/2011 10:44 am
 cp
Does your Elixir specifically state it's for IS 185? I ask as when I got my Juicy's, they came with both IS and post mounts.
You could always send the additional adaptor you link to above back - CRC are good with returns, even if they struggle to send stuff out, IME!
Posted : 22/12/2011 10:48 am
