Brake hose frame fi...
[Closed] Brake hose frame fittings (the welded/brazed types) in the North West
Looking to get my Kona Unit re-sprayed but fancy replacing the old cable guides on the top tube with hose guides/clips.
ie these
anybody know where I can get them? I can always get them welded on at work
OR
Somewhere in the Northwest that can do the mod for me?
Ta
Dave
Posted : 17/01/2013 9:45 pm
Yes to both - well, I'm in Glasgow but can either braze them on for you or post you some.
Edit: aluminium? Can't braze that, but can send you some...
Posted : 17/01/2013 9:57 pm
Ben, how well do these things stay on with epoxy?
Posted : 17/01/2013 9:59 pm
Pretty well, apparently - not tried myself but others have.
I've also got some alu ones which attach with little pop rivets.
Posted : 17/01/2013 10:01 pm
Paul hewitts will do it.
Posted : 17/01/2013 10:04 pm
aha good shout
cheers ben, i'll try Mr Hewitt first, if he won't/can't/costs too much i'll give you a shout if thats OK.
It's a steel frame so it will be either brazed or tig'd
Thanks
Dave
Posted : 17/01/2013 10:09 pm
Could you not dremmel them in to the required shape ?
Posted : 17/01/2013 10:12 pm
Ah okay, I thought the pic was of the same frame ๐Ÿ™‚
Posted : 17/01/2013 10:21 pm
not really the ones on it ATM are the old type ie outer cable guides/stops
Posted : 17/01/2013 10:24 pm
Hiya dave - how many do you want?
I've just had a count up and got 9 in the garage and can silver solder them if you want - swap you for some beer ๐Ÿ™‚
Paul W has my mobile / email etc.
Each one needs a little work with a file to match the diameter of the tube (the raw casting has bits of flash etc to clean off).
Posted : 17/01/2013 10:34 pm
Ben,
Do you know if such a thing exists to replace one of these
with something that could take an outer cable and act as a stop.
What i am thinking is something like this
but with a stop on one side and a cable clamp on the other for the rear gear cable.
Posted : 17/01/2013 10:44 pm
Cheers Mick_r
I'll get in touch with paul and get your number if thats OK
thanks for the offer, I need 2 maybe three.
I'll take the others off and give you a shout
Posted : 17/01/2013 10:56 pm
No problem - whenever suits you.
I've got a basic setup at home for silver. I usually hold them in position with loop of twisted mig wire then cut it off after soldering.
I take it you'll be using Fastline again for paint? I need to pay them a visit sometime (need quotes for some boring work stuff and a couple of frames to powder before the Bespoked show in April).
Posted : 17/01/2013 11:09 pm
Yip fastline again, the guy seems honest and good value.
Posted : 17/01/2013 11:26 pm
RM - I don't know of anything like that, but shouldn't be hard to make one - it's possible to get steel under-BB guides so could get one of them and braze on the stops as needed.
Posted : 18/01/2013 12:40 am
