I have hayes stroker ryde disc brakes and have got a Superstar 160mm Post Mount to IS Adaptor. When I tighten up the brake adaptor there is slight subside on the calliper which causes one brake pad to rub and not run freely at all? I've tried washers but it still doesn't effect the alignment of the calliper and the pads rub? I have rockshox pike forks. What do I do to fix this??? It's rubbing on one side of a pad by the way. Other pad doesn't touch rotor when braking.
Posted : 25/09/2011 6:17 pm
