Bottom Brackets...?...
[Closed] Bottom Brackets...???
Can anyone explain to me (in really simple terms) the difference between the Bottom Bracket decriptions...
what's the difference between a BB30 and a Mega-Exo for instance?
โ“
Posted : 18/03/2010 5:34 pm
Square taper - standard axle with square ends onto which the cranks pressure fit. Bearings are internal inside a cylinder which screws inside the BB shell
Octalink/ISIS - similar except that the axle ends in a splined interface
Mega Exo/EBB etc - bearing mount outside the shell and a separate axle (usually attached to the drive side crank) is pushed through
BB30 - new larger format allowing larger bearing to be used
Posted : 18/03/2010 5:40 pm
Do your own research you slacker!
Posted : 18/03/2010 5:43 pm
Okay, Okay...
...are there any issues with compatability for instance fitting a Mega-Exo BB in to a BB30 frame? Can this just be sleaved or is this a no-go area? ๐Ÿ˜
Posted : 18/03/2010 7:21 pm
you can only fit a BB30 BB into a BB30 BB frame
unless someone makes reducer cups but i doubt it
Posted : 18/03/2010 8:33 pm
๐Ÿ™„
Posted : 18/03/2010 8:39 pm
Thanks for the info - I'm definitely more enlightened ๐Ÿ˜€
Posted : 18/03/2010 9:19 pm
