To fit a thicker compression ring. I've done this before with ease ona different RP23. This airsleave just spins though both ways with no tightening/untightening apparent. You can actuate (?)it slightly by 1mm (top of sleave to housing but it wont unscrew.
Ideas?
(It holds air etc)
Xv air can? Hold the bottom of air can ( by wiper seal) to turn it 😉
STEP
AWAY
This one- grey/black decals:
Www.flickr.com/photos/30625376@N06/10332372733/lightbox/
loco +1
Whoa, hold on, I think that is a higher volume can, there is a circlip thing you need to take off first.
http://singletrackworld.com/forum/topic/fox-rp23-boost-valve-high-volume-air-can-problem-help
Ah!
No you don't need to remove the circlip unless you're replacing the seal for the xv sleeve 😉 if the can is too tight you can use a rubber strap wrench, make sure you've let the air out too 😉
