Just ordering some parts for a mate and he's also looking at a new cahin ring. Does anyone know if the SRAM X-Sync 2 Steel Direct Mount Chain Ring fitted is Boost or not??
Linky to bike - https://www.specializedconceptstore.co.uk/product/13952/2019-men-s-stumpjumper-comp-carbon-27-5-12-speed/
I can see its DM and assume its Boost but does anyone know for sure
Carlos
It should be boost and have the offset stamped on it if you have access to it. Both ours are 3mm
Thanks Tracey.
I don't have access to his bike atm and thought I'd ask on here so I can add it to the basket of other bits.
i thought boost was 6mm?
Stumpy SRAM boost direct mount chain rings on ours are 3mm o/s
Standard is 6mm
Boost is 3mm
BB 30 is 0
wow there pricey
Yeah pricey indeed, but he's running NX and they are about £15
Only linked to that for offset. Uberbike of Superstar do good aftermarket, not tried a steel one yet
