Singlespeeding seems to be disagreeing with my less than perfect lower back ๐ So is there a cost effective way to bodge any gears onto a pompino or is it cheaper to just give up and get a geared cross frame.
It's 120mm back end. Shame coz I like it.
[URL= http://i626.photobucket.com/albums/tt348/shawnmcfarlane/1-DSC03239-001.jp g" target="_blank">
http://i626.photobucket.com/albums/tt348/shawnmcfarlane/1-DSC03239-001.jp g"/> [/IMG][/URL]
full length cable + one of these of the back. You'll need to bodge the shifter on if you don;t switch to sti's too. - Minoura do a bar extension thing that might allow it or maybe a bar end shifter?
You can get bolt on cable stops for the front from SJS etc if you want more than one chain ring.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=249 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=249[/url]
derailleur wont work.
sturmey do some 120mm hub gears, in 3/ 5/ 8 speed.
no knowledge on the subject, but ill chirp up anyway.
Hub gear?
*makes note to read the whole post next time*
Having said that, it's steel - just spring it apart a bit to get 'proper' hub in there ๐
Does anyone do sturmey hubs ready built in 700c rims? Might be worth a go depening on price
You could try one of these?? http://road.cc/content/review/33373-sturmey-archer-s2-kickshift-hub
With the weight and cost I'm thinking a geared frame might make more sense
What size is that frame...you know...just out of interest...
just what i was thinking flange, ive spent several years hovering over the buy button for a blue pompino
It's a medium, I'm 5'8"
