Bodging a single sp...
[Closed] Bodging a single speed freewheel onto a shaft.
I need to fix a single speed freewheel onto a 25mm shaft. Any ideas of a part to start with and modify? Seen the surley Fixxer and something called Drew's adapter but neither is ideal.
Posted : 06/04/2013 10:09 am
I think if you look on trike racing and velocoar websites you may get a few ideas.
Otherwise cut up an old freewheel fixed hub and open it out to fit the shaft, then weld on. (I'm chucking one out if you want one)
Posted : 06/04/2013 11:53 am
