Boardman MTR 9.0 re...
Boardman MTR 9.0 review
wpf-cross-image
There's a whole swathe of folk who'll be very happy on board this Boardman
Posted : 14/10/2025 10:53 am
Topic Tags
To sum up your review. It’s not rad enough for you but the plebs might be happy with it.
Posted : 14/10/2025 11:01 am
That may be a bit unfair Bruce, it sounds like Ben has given the bike a clear and fair appraisal — and it could suit a good section of this site's demographic.
I ride an older Boardman hardtail a lot, even more XC focused than this. It's great fun and often my bike of choice, but I don't (successfully) try to do the same things I would on my enduro bike.
Posted : 14/10/2025 11:26 am
Could you use a 9point8 slack-r to adjust the headset angle? Though 65.5 is hardly steep.
Posted : 14/10/2025 12:27 pm
If you’re trails aren’t especially steep
*grinds teeth...
Posted : 15/10/2025 1:17 pm
Nice to see they got ride of that hideous shaped frame on the last version. The old one was ugly
Posted : 15/10/2025 4:27 pm
That there is an slx cassette 😂, even says so on the back in one picture.
Posted : 17/10/2025 7:59 am
Yes the big black aluminium sprocket gives that cassette away as an SLX M7100.
I suspect I'd be one of the happy plebians. 130mm travel is good for a do everything bike in my book. However if it is too slack and long then it'd be slow/hard to wrestle around the tighter stuff on an XC circuit.
Does greater slackness really increase capability/speed on steeper stuff, or does it just make things feel more stable?
Posted : 18/10/2025 8:04 am
Does greater slackness really increase capability/speed on steeper stuff, or does it just make things feel more stable?”
The former because of the latter!
I experimented a lot with this with my previous pair of hardtail and full-sus bikes, with anglesets, fork lengths and flip-chips. It made more difference than I expected when riding trails nearer the upper end of my gnar-ability.
The slacker the head angle, the longer the front centre and the lower the BB, the better the bike was on steep and rough trails. I didn’t take things very far, so I’m sure there’s a tipping point - but I got down to about 63.5 deg, sagged BB height of about 290mm but not so long on the front-centre (bikes were only about 450mm reach and 27.5 160mm forks).
My current bikes aren’t quite as low or slack as those extremes but the front-centres are longer (and the chainstays a bit too). That seems to work better all round for me - but I’m sure some would find them too slow to turn on twisty trails, they do require an active riding style.
Posted : 18/10/2025 11:47 am
My 29er hardtail is at 63.5* with a 130mm fork (SuperStar -2* Slackerizer)It’s only got a 440mm reach and 440mm rear centre but being 2* slacker than when I bought it has made it so much better at descending without it becoming worse on the flats and climbs.
My old Orange Alpine 160 was about the same after I fitted a -2* headset, longer fork and offset shock bushings and again rode better in all directions.
My ebike is about to get a Slackerizer to bring the head angle down to a about the same while allowing be to run it in the High/steep setting to allow a slack head angle but keep the same at angle and BB a bit higher.
I have yet to try a bike that wasn’t improved by a slacker head angle (although I haven’t ridden many modern super slack DH bikes enough
Posted : 18/10/2025 1:44 pm
Not a bad bike by any stretch but in the current climate £2,500 buys you a heck of a lot of bike.
canyon selling spectrals with far far better spec (and more “modern” geometry) from £2,300
saracen Ariel 30 posh edition is £2,500 (and won Singletrack bike of the year at £4K rrp)
etc etc
Posted : 18/10/2025 10:15 pm
