Sorry for lack of pictures, but Look keo2 pedals have a needle bearing where the end of the spindle sits. Like a circular bearing at the bottom of a shaft, with access only from the top. How might this be removed?
It's a carbon pedal body so prob doesn't need a ton of force to pull it out, but need to improvise some thing that can be poked in and will expand to grip the bearing and then remove it.
Posted : 31/03/2026 11:03 am
Would something like this work - https://www.bearingprotools.com/collections/hub-bearing-tools/products/wind-out-blind-bearing-puller
Posted : 31/03/2026 3:16 pm
Google blind bearing puller and see which looks like it might fit. You'll probably need something with a slide hammer rather something that needs winding out
Posted : 31/03/2026 6:06 pm
