Bleeding hayes nine...
[Closed] Bleeding hayes nine brakes
2 Users
Just got one little question I'm hoping someone can help me out on, when you bleed the caliper by squeezing the bottle then releasing it to draw air from the caliper do you need to do close off the lever? Otherwise it seems to me that you would just be pushing fluid through the system then drawing air back in when releasing it?
Posted : 17/04/2010 10:51 am
close it off at the caliper after pushing the fluid through.. leave the system open at the lever end for as long as possible. make sure the cable lever etc is flowing upwards bottom to top, for air bubbles to escape.
Posted : 17/04/2010 11:24 am
I meant the bit it says to do before, where you use the bottle to squeeze fluid into the caliper, then release to draw air out. Does this not draw air in from the lever end?
Posted : 17/04/2010 12:00 pm
