bleeding brakes - s...
[Closed] bleeding brakes - shim Zee question help
5 Users
So i brought a epic bleed kit as i thought it was about time i did it myself and yay great result piece of piss after realizing i had to put a bleed block in ... butttt lever doesn't engage as quickly as my other unless you give it two quick pumps then its rock solid and has the biting point i want . i took ages over the bleed but is this just still air in system . if so connect open res and pump again with syringe attached ?
Posted : 18/05/2014 8:54 pm
willing to bet it's the rear that has lots of lever travel.
Posted : 18/05/2014 11:49 pm
unless you give it two quick pumps then its rock solid...... is this just still air in system
yup, give it another bleed
Posted : 19/05/2014 5:20 am
Yup, re bleed, rear takes a bit more time and patience. On a set of Deores I did I shaved a bleed block down so the pads sat closer to compensate for the extra travel, seems to be a common issue (though none of my own have it)
Posted : 19/05/2014 5:40 am
Had the same problem with my rear zee. Took longer when drawing the oil back down out of the caliper and one huge bubble emerged, and now all is fine. Previously tried moving the pads as suggested but this just messed up the better modulation feel zee's have over other shimano brakes I've tried.
Posted : 19/05/2014 6:50 am
