Bkool pro 2 with Zw...
[Closed] Bkool pro 2 with Zwift on Apple TV. Possible?
My laptop is not cutting it for zwift. Way too low spec.
There is a lot of old noise on Google saying you can't link the bkool to zwift via apple TV. Do you know of anyone who does this?
A used 4k apple TV would be spot on if it works.
Posted : 03/02/2020 12:01 am
The new bluetooth smart one yes you can. Theres a slight issue with the fact that the apple tv only takes 2 bluetooth inputs so you basically cant have power, cadence and hr together.
Ive just done similar but moved from old bkool to wahoo as its supposed to combine cadence into the same channel as power leaving one free for hr, just got it all rigged up ready to test tomorrow. Laptop wasnt cutting it here either, hopefully the atv will run it ok.
Posted : 03/02/2020 12:10 am
I think you can use the companion app on iPhone to give you an extra BT device or two.
https://zwift.com/uk/video/how-to-cycling/pair-devices-appletv
Posted : 03/02/2020 9:15 am
Just another thought, given mine its first go today and bear in mind you might need new sensors, my cadence and hr are ant and that wont work with the apple tv. So its new bt ones of those too.
Posted : 03/02/2020 4:05 pm
