Bird Aeris 9 - 52 o...
Bird Aeris 9 - 52 or 55 mm chainline cranks?
[#12859583]
52 or 55 mm chainline (shimano) cranks for the Aeris9? Both should work on paper with a boost spaced hub but I've never managed to work out whether there is any real reason to use one over the other? Wider q factor doesn't bother me. I can't find anything on the Bird product page.
Ta,
S
Posted : 18/06/2023 8:19 pm
I can check what version of XT they have fitted to mine when I get home tomorrow if it helps.
Dan from Bird has posted 52mm for boost and 55mm for super boost in relation to the AM9 if that helps
Posted : 18/06/2023 8:35 pm
stompy reacted
If 52 gives chainstay/chainring clearance, that’s what I’d go with as it gives a better chainline.
Posted : 18/06/2023 8:39 pm
OK, ta. Trying to find 165mm cranks as I'm having a devil of a time with root/rock pedal smashes. The only in stock slx options seem to be the 55 mm version.
Posted : 18/06/2023 8:49 pm
You could try phoning Bird, they supplied 165 XT's on my build.
Posted : 18/06/2023 8:51 pm
I have some SLX FC-7120 165mm (55mm) which have done 20 miles, still have the box (no chainring).
If you get stuck DM me.
I'd go 52mm.
Posted : 18/06/2023 10:01 pm
I’ve got those slx 7120 165mm cranks for 55mm chainline on my aether9. They just have a longer spindle and two more spacers than the 7100 52mm chainline version.
I fitted them with one spacer from the drive side on the nds to move the chainline back in to 52mm.
Posted : 18/06/2023 10:18 pm
And Q Factor jumps from 172mm with 7100 to 178mm ( the two 3mm spacers and a longer axle) with the 7120 - if that bothers you.
Posted : 18/06/2023 10:52 pm
Personally, despite what the manufacturers say, I think 55mm chainline on 148mm boost is rubbish unless you've got decently long chainstays.
I'd default to 52mm. That said, for my riding I'm happy to run a 30t chain ring which helps with chainstay clearance, obviously.
Posted : 18/06/2023 11:07 pm
Thanks all, I'm running a 30t ring so no issues with clearance. Will wait for 52 mm sets to come back into stock
Posted : 18/06/2023 11:14 pm
