Bike maintenance la...
[Closed] Bike maintenance lapse
5 Users
For some one who should really know better, and someone who regularly harps on to others about keeping their bikes in order i have been truley humbled in the last two days.
Yesterday:
flat tyre miles from home, no pump!! long walk
Got home and found i had let the tyre sealant dry up...6 months since last filled!!
noticed creaking noise but decided that bike spray would fix this.
Today:
Half way to work the chainring fell off spider!!!! that would be the creaking noise then..
Checking over components when i eventually arrive at work and the rear brake caliper was also very loose...that would be the annoying rubbing and slight rattle then..
Conclusion...Practice what you preach my man.
Posted : 04/11/2010 1:36 pm
im saying nothing.
Posted : 04/11/2010 1:45 pm
try this... carry a Leatherman multi-tool religiously for 6 months. Then one ride decide to ditch it and spare the weight. And on that ride have your gear cable pull through and shred at the 8 mile mid point...
I'll just get my leatherm.... F.........!!!
Posted : 04/11/2010 2:18 pm
Never thought about the sealant drying up!
How often should you top it up?
Posted : 04/11/2010 2:47 pm
[i]How often should you top it up?[/i]
It depends - normally, if you can't hear it sloshing when you shake the wheel it's time to top it up. I normally bung a bit more in through the valve evry 2-3 months.
Posted : 04/11/2010 2:52 pm
Ok thanks, I'd better go and have a listen to my wheels then! 🙂
Posted : 04/11/2010 2:54 pm
