Bike Fit Issue - co...
[Closed] Bike Fit Issue - could be expensive
If the problem is too much weight on the hands then a layback post will make it worse. You will be more leant forward and more weight will be on the wrists.
No, it can mean a better balance that takes weight off the bars if anything. You may increase reach but it'll be more tolerable with less weight tipping fwd.
Saddle position is critical anyway - you need to set the saddle to be correct in relation to the bb, then sort out the reach after that.
Sort of agree, in that position over bb is important in same way as saddle position is - same thing really, for balance and comfort, good fit starts there. Position over BB as in KOPS relation for pedalling efficiency etc, less so and not really where fitting should start (often does though - maybe only a driver for fit for performance riders who can tolerate a less comfy position)
Posted : 09/06/2014 12:14 pm
OK OK OK 🙂 I will move the damn brake levers just to keep you lot happy! To my point about not covering them all the time, I use this bike for pootling along with the children and for long non technical XC rides so the need for sudden braking is lessened. I do ride with brakes covered on the full suss while on more techie stuff.
So a divided opinion on the layback seatpost approach, if I can get hold of a cheap one I will let you know.
Oddly my wife didn't bat an eyelid when asked to photograph me riding round the garden, maybe if I was naked she might have reacted differently but who knows!
Posted : 09/06/2014 12:20 pm
Can I confuse things and say that lower / steeper angled brake levers usually increase arm-pump for me compared to moderately angled levers? : ) Dropping the wrists a little is no bad thing. Anyway, get your balance as right as it can be on the bike first )
On the layback post thing, if you have time read Keith Bontrager's 'KOPS - debunking the myth' essay, or scan through it. It's quite detailed but the theory in it is some of the most useful out there. A DH skier analogy sums this aspect of fitting up - get into a DH skier position, sort of similar to on a bike. Similar enough to illustrate a point anyway. Your c of g is over the balls of your feet when you're balanced. The longer (or heavier) your upper body the more your backside + lower body needs to be behind your feet for balance. Once your torso is in balance you can move your arms around a fair bit (ie bar position) and it makes little difference, ie you can set bars up for handling not just fit. But if you want to shift your c of g fwd past the balls of the feet you need something to support your hands - this is the 'weight on the bars' feeling that causes wrist pain for many.
So sliding the saddle back can be a way to take weight off the hands or account for different rider builds. And if you start with KOPS for saddle position, you're stuffed if your c of g isn't central in that position. For average builds it's close and a fair quick-fit guide, but there's more to it.
Posted : 09/06/2014 12:28 pm
Page 2 / 2
