Best way to remove ...
[Closed] Best way to remove a star nut?
As the title really. Forks have a star nut fitted, new headset is a hope with head doctor. How can I easily remove the star nut with out wrecking my forks.
Posted : 25/06/2015 10:07 pm
Hammer it through from the top (in fact you only need to hammer it down far enough for the HD to fit)
Posted : 25/06/2015 10:08 pm
Leave it in.Head doctors are a pita anyhoo.
Posted : 25/06/2015 10:09 pm
I would usually just bash it down a bit below where the head doctor needs to go. Or just continue to use the star nut actually as I prefer them to head doctors or similar devices.
Too slow but both my suggestions were covered. A fail, but a commendable effort ๐Ÿ™‚
Posted : 25/06/2015 10:10 pm
If you are going to whack it all the way through ensure that you steerer isn't internally re-enforced towards the bottom like my Marzocchis.
One technique is to drill out the center portion so that the two disks are no longer attached together - they come out with pliers pretty easily then.
Posted : 25/06/2015 10:11 pm
Don't do it. Star nuts are much better than a head doctor.
Posted : 25/06/2015 10:26 pm
^^ What he said ^^
Posted : 25/06/2015 11:45 pm
Tapered forks weren't invented to improve stiffness or make anyone money... it was all about making it easier to knock a star nut out the bottom.
Posted : 25/06/2015 11:51 pm
Yep, use it, best tool for the job. Expandy bullshit is only for when you can't use anything else.
Posted : 26/06/2015 12:12 am
