Best way to really ...
[Closed] Best way to really clean a rotor
So I'm pretty sure my rotor and pads have had lube sprayed all over them. Luckily the pads are almost gone so they're straight in the bin but I need to ensure the rotor is clean before the new pads touch it. So, what's the best way?
Spray with isopropyl and wipe down? Scrub with wire wool too? Attack with a gas burner?
Posted : 03/07/2017 5:19 pm
If I have the rotor off the wheel, I fill a Quality Street box lid with about 2mm deep of meths and soak the rotor in that.
APF
Posted : 03/07/2017 5:20 pm
Scrub with cream cleaner and rinse off with boiling water.
Posted : 03/07/2017 5:30 pm
i wouldn't use meths. leaves a residue. IPA is better.
Posted : 03/07/2017 5:37 pm
Normal dish washing soapy bubbles will remove the contamination. Followed by a wipe with IPA and some blue-roll.
Posted : 03/07/2017 6:08 pm
Dishwasher.
Posted : 03/07/2017 6:13 pm
Meths is cheaper
APF
Posted : 03/07/2017 6:15 pm
The thing is, always in the back of your mind will be, "It doesn't feel quite as good as before. Or does it? Have I really decontaminated this rotor? I'm not sure. No, it's good. Would I have more stopping power if I'd binned it and bought another?..."
Posted : 03/07/2017 8:17 pm
1. Be careful applying lube, although a lot of people don't realise GT85 or WD40 is actually a degreser.
2. I use either £1 Nail polish remover which is acetone or £2.39 http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/maintenance-fluids-and-greases/maintenance-fluids/?NOR2897333500&0&cc5_858&gclid=CKeN2t_r7dQCFfEK0wod8OsNWA
3. Always wipe down with an absorbent cloth eg paper towel or poundshop jiffy cloth.
4. Finally, ride bike down a wee hill repeatedly till brake disc hot to burn off any residue.
Posted : 03/07/2017 8:29 pm
I usually use a shallow baking tray, a good slug of Trichloroethylene (Basically a industrial alcohol cleaning agent) then set light to it (stand well back and best done outdoors) till it's all burned up. Wait till it's cooled and then pop the disk in the oven at max for 10min...hasn't failed me yet and leaves no residue...other than the wife smacking me over the head as her nice baking tray is toasted 😉
Posted : 03/07/2017 8:36 pm
Trichloroethylene is a very effective degreaser but banned due health risks! So if you use it take care.
Posted : 03/07/2017 8:43 pm
It's the only way to be sure...
Posted : 03/07/2017 8:48 pm
Soak it in coke.
Posted : 03/07/2017 10:20 pm
I use brake cleaner , radical or what.
Posted : 03/07/2017 10:24 pm
If you think it's still not right after degreasing try the old motorcycle trials trick of dragging them until hot then spraying with neat water. Restores the bite quite well.
Posted : 03/07/2017 10:30 pm
In my experience, having tried all sorts of things, muc-off works best - or similar bike cleaner.
Lube and grease is not hard to get rid of, no need to over-think this. And that's me saying that.
Posted : 03/07/2017 10:44 pm
Lighter fluid, lighter.
Job jobbed.
p.s. It gets hot. Like, really hot. Hence the pliers.
Posted : 03/07/2017 11:04 pm
My experience of what finally worked sorting out brake-fluid contaminated* rotor and pads living in non-hilly areas**.
1. Set oven to it's hottest setting (230C ish?)
2. Put rotor and pads in washing up bowl.
3. Pour on boiling hot water fresh from the kettle
4. Add washing up liquid
5. Wash 'em - careful now it's pretty hot
6. Repeat maybe - I did
7. Rinse parts in normal tap and then finaly boiling water
8. Put parts on (non-greasy) rack
9. Put parts in oven for 15 mins or so
10. Take out
11. Most important part - WAIT 10 mins or so
12. Refit to bike.
13. Ride
* - Which idiot designed brake systems such that brake fluid effectively ruins brake components ???????
** - There is an alternative to this. Live somewhere hilly. When I was in the south downs my solution was to ride for a couple of hours - some energetic desceding just burned off any conaminants - problem solves - happy days.
Posted : 03/07/2017 11:07 pm
Blowtorch on the rotors. Just be careful to avoid the spokes.
Posted : 03/07/2017 11:47 pm
IPA
Posted : 04/07/2017 6:43 am
IPA
That's just a waste. Carlsberg will do.
Posted : 04/07/2017 7:11 am
Singletrack is definitely failing. Only 21 replies on how to clean a brake rotor 😀 I was expecting at least 6 pages by now!
Posted : 04/07/2017 7:53 am
The thread is only 15h old - you need to give it time to mature. Like a fine[s]MILF[/s] wine.
Posted : 04/07/2017 8:36 am
Degreaser, then dishwasher.
Posted : 04/07/2017 9:06 am
Mine will be going in the oven this evening. It has always worked for me.
Posted : 04/07/2017 9:29 am
I recently used some Iron Rain which is a deposit remover for car body work then used halfords brake cleaner and they are much better, plus quite a lot shinier which is nice.
https://liquidelementsuk.co.uk/products/iron-rain-v3-fallout-remover
http://www.halfords.com/motoring/engine-oils-fluids/brake-clutch-fluid/halfords-brake-cleaner-500ml
Posted : 04/07/2017 9:39 am
squirting lighter fluid on a burning disk...I had a bottle of meths explode in my hand doing something similar. luckily meths is quite a cool flame and they put me out quite fast 😯
Posted : 04/07/2017 9:41 am
I use Halfords clutch and brake cleaner.
Cheaper then the bike specific stuff and better IMO
Fire sounds fun though
Posted : 04/07/2017 9:48 am
alexpalacefan - Member
Meths is cheaper
APF
So you'd rather gets something that does a less than perfect job to save a few pennies.
Do you save them up for when you need new teeth?
Posted : 04/07/2017 9:57 am
Plenty of people are though!
Brake cleaner, possibly new pads but even they can be decontaminated, then go and get them hot is all that needs doing. Anybody who bins a perfectly good brake disc because it's got a bit of brake fluid, oil, grease etc on it must have more money than sense 😆
Posted : 04/07/2017 10:19 am
Take it off and put it in the dishwasher.
Posted : 04/07/2017 10:25 am
I'm going for new pads as the old ones are barely there, and the rotor just came out the dishwasher. 🙂
Posted : 04/07/2017 11:13 am
Brake cleaner
I have always found that brake cleaner ruins them. Clutch cleaner on the other hand is great but expenisve.
Posted : 04/07/2017 12:36 pm
