What are your thoughts as just purchased a frame without a shock...
If you would like to make offers feel free...
You won't go far wrong with an RP2 in my opinion, or a coil works well too, I've had both on mine and both where good,
The correct shock tune is what makes the biggest difference, I found a high compression tune made the rear end feel [i]dead[/i] and a medium tune felt spot on...
Best shock I ever had on a TNT or HL Spot was a plain jane Fox Float RC rear shock that had been Pushed by TF.
It did not have any of the RP23 platform gubbins, was a light tune, was very active and very plush, did not blow through the travel like RP23's do and was soooo good that I still have it 4 years later now, have switched it onto my DW Spot and just had it retuned/serviced by TF!
Find a cheap but good condition standard Float in 190 x 50mm and get it to TF.
