I've checked Lumicycle site for info with no luck. I'm sure it's there just me being incompetent.
I've got Li-ion battery do I fully charge it and put away? Does it need a top up e every couple months, run through a discharge/ charge cycle?
Cheers.
Li-Ion batteries don't like being stored for long periods at 100% charge, this can give them a reverse memory effect to what you used to see with NiCads.
They are best stored for long periods at approx 50% charge state. Although the battery is not being used for long periods the protection circuit will still drain the cells within the battery, this may only be few millAmps as it monitors the battery as a whole but over time especially if it left in a low state of charge it can discharge the cells/battery below the end of discharge (low cut off voltage) limit and it may not recover when putting back onto its charger.
So best left in about 50% state of charge and used once a month for a few minutes and then put back on the charger for a few minutes to make sure everything is still good. Stored in a nice cool place is best but not in the fridge or freezer.
Whilst you are still using it faiirly regularly it is ok to keep it fully charged and just check the battery after each ride to make sure it's not wet or damp from the ride.
Any questions please feel free to email me.
Smudge
Thanks Smudge that is a very comprehensive answer and I will get it sorted.
Ta mate
