best diy/ghetto/spl...
[Closed] best diy/ghetto/split tube/g tape/other method for tubeless ( fat and 29+ rims)?
apologies for being somewhat lazy re research / reading of previous threads /watching youtube vids etc but I'm new to tubeless and would like to convert some surly rims ( drilled large Marge and rabbit holes ) to run as tubeless. Really wanted to ask those in the know what's currently considered the best/most reliable/easiest method . There is so much info out there some using rim strips then gorilla tape then split tube + thin layers of foam etc.
What's really necessary ? I presume split tube is heavier and all the options run best with some sealant.
i would appreciate your advice..tips and tricks as i'd like to do it right first time ! I have an airshot for seating btw.
thanks for your time
Bill
Posted : 22/04/2017 5:45 pm
On my fatbike, I used gorilla tape sticky side out then sticky side in, then a split tube.
Works faultlessly.
Posted : 22/04/2017 5:56 pm
Just used a section from a really cheap yoga mat to fill the recess in the rim, split baby fat tube and sealant.
Probably not a great weight saving but has not let me down (yet!)
Posted : 22/04/2017 7:56 pm
I've got some 24x4 tubes (new) for sale if you want to try split tube
Posted : 22/04/2017 8:28 pm
Split tube all way through.
Both on fat - BR710 - and 29+ - Rabbit Hole.
[url= https://krzywekolo.wordpress.com/2016/06/03/ghetto-tubeless-dla-kociny-2/ ]Ghetto fat split tube[/url]
[url= https://photos.google.com/share/AF1QipN6yGiOFLMMVZVT1_ELjXlGMp8hyJhpbJ-gVzV60BgMPWH03L235VNWXyFkmRO22A?key=RUxkVGdtQlo0bkVaT3BEaUNrSkFxQU9DZHNRRm5n ]Ghetto 29+ split tube[/url]
Cheers!
I.
Posted : 22/04/2017 8:44 pm
this on my dt swiss 2250 and didnt take to long ๐Ÿ™‚
Posted : 22/04/2017 8:52 pm
On "normal rims" I have had two split tube set ups.
Both have been faultless from a sealing and reliability point of view.
On a narrow rim the tube can make the bead seat narrower still. A 2.3 tyre on an old school internal diameter 17mm rim is pushing it.
Posted : 22/04/2017 10:45 pm
29+ Rabbit Holes tubeless here for about 2 years with just Gorilla tape. No probs at all.
Used 3 layers - first sticky side in to cover the cutouts, and then inner layers the other way around.
Posted : 22/04/2017 10:50 pm
