Being put off by XX...
[Closed] Being put off by XX1
66 Users
Can you guys mixing and matching post a full list of bits please? I've lost track!
Posted : 15/12/2014 9:41 am
I'm using:
- XX1 chainset/chain/cassette
- XTR M9000 shifter and GS rear mech
Works very well. Will change to an Absolute Black spiderless chain ring in the spring.
Posted : 15/12/2014 9:45 am
Great - keep us informed of 10t and 42t performance.
Posted : 15/12/2014 9:48 am
It's fitted to a hardtail, so no reason to think it will work any different IRL to on the stand! But yes, will update.
Saved a tiny bit of weight too - XX1 rear mech was 244g, XTR was 222g. XX1 Grip Shift was 89g, XTR was 104g, grips were exactly the same as I went from Chunky to Racer's Edge ESIs. So a whopping 7g saved. Will fit alu clamp bolt into the shifter at some point for pimpyness, probably take me to a monstrous 10g saved.
Posted : 15/12/2014 10:14 am
every little helps njee - im nursing a hefty 110gram gain in the rear cassette, changing from an XX 11-36 to an XTR 11-40!
Posted : 15/12/2014 10:48 am
Should've gone for the XX1 cassette then, cheap weight saving despite the extra expense 😉
Posted : 15/12/2014 10:55 am
I have one lot fitted on a 2015 Nomad and I am fitting another lot on a Solo.
I using the following parts:
XX1 Chain and Cassette,
Raceface Sixc cinch crank and narrow wide ring,
XTR M9000 Shifter and Rear Mech.
Working spot on with no issues at all and I have a fair few miles on it now.
Posted : 15/12/2014 11:26 am
I'm using
XX1 Cassette, Chain, Cranks (30t), mech.
X01 Shifter
I find it absolutely faultless. Only think i fancy changing is to a spiderless chain ring and to drop to a 28t to avoid using the 42t so much.
Posted : 15/12/2014 11:45 am
The thing is if this works so well why would anyone buy the shimano 11-40 cassette (or front mech) ?
I'd have tought shimano would have managed to work in some sort of incapability myself.
Posted : 15/12/2014 12:49 pm
Am I right when I say you can use the Shimano 11 speed cassette without changing your hub driver body because the cassette is the same length as a 10 speed?
Anywhere selling a 1x11 XTR groupset with brakes?
Posted : 15/12/2014 1:40 pm
Curiousyellow
Correct, you can use an 11 speed cassette with a 10 speed hub.
I have a brand new 11 speed cassette and shifter for sale if interested.
Duplicate gift!
Posted : 15/12/2014 3:53 pm
Cheaper, particularly if you already have a hub, think this is particularly prevelant with people assuming that by the time they replace they'll have the option of XT cassettes at £60 or so. Daft otherwise though IMO, the range on the SRAM one really is significantly better.
Posted : 15/12/2014 3:58 pm
Guys, just looking online at the Shimano 1 x 11. What cage length rear mech are you running and have you kept the same chain length as with the SRAM set up.
Ta
Posted : 16/12/2014 10:35 am
GS mech, I have kept chain the same as with SRAM, but I could shorten it by at least one link, possibly two, didn't want do so until I was happy it was going to work!
It's not doubled up on itself in the 10, so I wasn't hugely worried.
Posted : 16/12/2014 10:40 am
Page 3 / 3
