Bearings - 7- 21-31...
[Closed] Bearings - 7- 21-31mm Why cant I find any?
I need to replace the bearings in a few BB’s I have but I can find any online
I’ve measured them as 7mm OD 31mm ID 21mm
I need 9 or 12 of these if anyone knows where I can find them.
Any help would be appreciated
Posted : 30/05/2013 9:24 am
shimano had them made to a special design to prevent exactly what you're trying to do 🙁
BETD and so on sell quality replacements but, tbh, complete new XTR BB's from Germany often come out cheaper.
Posted : 30/05/2013 9:26 am
If they are for HT11 BBs then you need 6805 2RS or 61805 2RS. BUT they are 7mm wide, Shimano use a 6mm wide bespoke version in their cups.
Hope also use a bespoke version, so no aftermarket bearings available.
What cups are you using?
Posted : 30/05/2013 9:57 am
21mm ID? What's that from? Hope is 24mm, Shimano 25mm without tophats.
Posted : 30/05/2013 10:16 am
these are for KCNC titanium ISIS bb's
they take three bearings per BB.
the Bearings don't have any markings on them, nothing at all.
Posted : 30/05/2013 10:20 am
There are some available [url= http://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=0&keywords=21.5x31x7mm ]HERE[/url] but they have an extra 0.5mm on the internal diameter.
My Control Tech ISIS BB uses the above bearing size, just thinking that maybe yours is the same...
Posted : 30/05/2013 11:39 am
Thanks for the link.
Is thtat price for each bearing ?
Posted : 30/05/2013 8:24 pm
Yessum. It makes you wince when you realise you need three per BB, but if you figure-in that I got over four years out of my last set*, it's not too bad. From new I clean and refill with my own bearing grease before fitting. It's an OCD thing...
* Obviously this will depend on the sealing of your component
Posted : 31/05/2013 11:16 am
