BB30 Spanner
[Closed] BB30 Spanner
has anyone got / seen one of these for sale anywhere? just been in my LBS and the best the bloke could find was one on amazon for over £50! they were about £10 on CRC but no longer in stock anywhere.
its only for my old hardtail, so if I'm paying that sort of money i'll buy a converter with a 2nd hand slx/xt
Posted : 05/01/2017 2:05 pm
BB30 is a press-fit bottom bracket design and doesn't need any tools except a press/drift to install/remove. If you're trying to install a 30mm spindle crank with oversize cups into a threaded BB shell (BSA30) , then suitable tools available from RaceFace, Hope, Rotor and probably Park amongst others - it's a bit bigger than a regular HT2 BB spanner
Posted : 05/01/2017 2:53 pm
If its for a 30mm crank (threaded not push fit) its a BBT79 Park tools 12 notch . I got mine from Fatbirds.co.uk .
Posted : 05/01/2017 3:16 pm
its a flat spaner for tightening the spacer on the non drive side
https://www.amazon.co.uk/FSA-Bottom-Bracket-Adjuster-Spanner/dp/B0029LD6FE
this
Posted : 05/01/2017 3:57 pm
OK, iz confused so it's actually for the cranks - my Google-fu failed too except Jenson in the US. Does annoy you when they specify proprietary tools and don't supply them with the bike/parts - RaceFace brought our Turbine Cinch cranks without the BB tool a few years ago - only found out after I'd bought the cranks.
Posted : 05/01/2017 4:10 pm
Any shop with a Windwave account can get one of those for you. They retail at £14.95 and they currently have 5 in stock. Part # is 230-5012
Posted : 05/01/2017 4:11 pm
cheers i'll look into that.
probably try a post in the wanted section on here later as well
Posted : 05/01/2017 5:49 pm
