Bars. Width isn't w...
[Closed] Bars. Width isn't width?
Between-two-trees width of 800mm bar fitted with SDG (Slater model, I think) grips is pretty much 820m; no outboard lock ring; hand position on the outboard edge. Moving those grips over to a 780 bar measures 800mm; hand position on outside edge. Moving those grips over to 760 bar measures 780mm; hand position on outside edge.
SDGs a bit skinny for my liking. Been comfortable in the past with Oury grips on an 800mm bar; outboard lock rings; hand position slightly inboard. So maybe 780mm outside edge of hands.
Is there a fat, squishy grip with no outboard lock ring, without the width extending properties of the SDGs so I can run bars with 780 between-two-trees width but with my accustomed grip width and comfort?
Or...
Is there a fat, squishy grip with the width extending properties of the SDGs that I could run on 760mm bars with a between-two-trees width of 780mm with my accustomed grip width and comfort?
Posted : 13/12/2018 11:19 am
Buy a hacksaw and use whatever grips you like?
Posted : 13/12/2018 11:25 am
Having a less bulky bike is really useful in lots of ways (e.g. moving bike in and out of a 4th floor flat; fitting in the car; zipping between trees).
If I can be in the same position on bars that are 780 end to end it is preferable compared to 800 bars. If I leave marks on the walls I get in trouble.
Posted : 13/12/2018 11:49 am
Maybe I'm just asking if there's a single lockring Oury equivalent
Posted : 13/12/2018 11:52 am
Here you go: https://www.specialized.com/gb/en/enduro-xl-locking-grips/p/132821
Posted : 13/12/2018 12:08 pm
Doh. I'd forgotten those. OH's bike has a pair of the Specializeds and I'm sat within 3m of it...
They measure ~31.25mm diameter and seem very soft on the surface down to a hard core. The two year old Oury's on my bike are >32.5mm and seem to have more depth down to the core. Specialized's on a 780 bar do measure up at 790 end-to-end so may be the best and quickest answer.
Posted : 13/12/2018 12:23 pm
I use GA2 Fat grips - really like em.
http://www.ergon-bike.com/en/article-ga2-fat.html
Posted : 13/12/2018 1:29 pm
 core
Those spesh grips are decent.
Posted : 13/12/2018 1:57 pm
I'm liking the look of those. Had GA2s before but the fat ones look mint.
Posted : 13/12/2018 1:58 pm
Supacaz Grizips might suit your needs. 32mm rather than 32.5 but good and soft, wear suprisingly well (considering the softness) and available in veritable rainbow of colours.... https://www.merlincycles.com/supacaz-grizips-lock-on-grips-120633.html
Posted : 13/12/2018 2:28 pm
"I’m liking the look of those. Had GA2s before but the fat ones look mint."
I really like me - the end caps are now replaceble incase of any crash damage!
I find them much better than the regular GA2 withought being too big.
Posted : 14/12/2018 12:50 pm
 geex
just turn your bars FFS
Posted : 14/12/2018 1:21 pm
Oh wow, I've just been geexed. [tugs forelock, mumbles: 'onored your geexship]
Posted : 14/12/2018 2:46 pm
 geex
lol
seriously though. move about your bike more, dip a shoulder as you aproach the first tree trunk and practice tiny manuals (just a front wheel lift using a push through your pedals and weight rather than your arms) with a slight bar turn to get through gaps narrower than your bars.
Posted : 14/12/2018 3:04 pm
