Bar End Shifter - t...
[Closed] Bar End Shifter - threaded locknut to handlebar
Anyone know how I can loosen the bar end shifter on this side? The other side came off fine, and I was able to turn clockwise on the locknut so that it loosened off the handelbar. This left hand bar shifter will not budge at all. Any ideas?
http://imgur.com/a/6Nutg
Posted : 21/12/2016 2:25 pm
Can you feel whether the expander is turning inside the bar or has the screw simply cross-threaded and is just turning? If the latter, trying to drill-out the screw might be best, but that might start spinning too? Is there any way you can get a screwdriver blade between the shifter housing and the end of the bar and pry it out?
Posted : 21/12/2016 2:45 pm
Success! Managed to pry it out, replaced my handlebar, BUT now when I try to put it back into the bar end the mechnanism on the shifter bunches up and won't go in at all. TYIA.
Posted : 21/12/2016 3:40 pm
It was threaded, now its not - it's stripped ๐Ÿ™‚
Posted : 21/12/2016 3:42 pm
Can i fit it at all? or is it fubar?
Posted : 21/12/2016 3:51 pm
I definitely need to loosen the screw inside the shifter so i can put it back on. Will ask at my local bike shop.
Posted : 21/12/2016 4:03 pm
They can be a bit of a faff. Assuming the bolt loosens and tightens okay but it still bunches up, try a wrap of electrical tape around it.
Posted : 21/12/2016 4:10 pm
Okay managed to get it back on, I loosened the shifter from the other end with a pair of pliers, now I need to find a way of tightening up the screw using the normal hex key method. I will go to a bike shop to get their opinion. Never let me near a bike. It takes me hours and I invariably screw up.
Posted : 21/12/2016 4:55 pm
Got this sorted in the end, I had the wrong size hex allen key. Borrowed another set and it worked so easily. Quite like the design of these very simple indeed.
Posted : 23/12/2016 11:35 am
