Does anyone know if I can remove the lever blade from the rest of the lever with risk of losing any brake fluid? I have the Avid floppy lever syndrome but the brakes have only been blead recently and are in otherwise good nick. Don't want to have to drain and re-bleed the system if I don't have to.
Posted : 05/12/2012 7:25 pm
Wouldn't bank on it, if you have to remove the circlip inside to release the offending gubbins, Sod's Law often comes into play and allows the piston to pop out.
Posted : 05/12/2012 7:54 pm
Should be no problem from what I remember. I changed lever blades on both elixir r and elixir 5 without having to bleed the system.
Posted : 05/12/2012 8:07 pm
yer you can,
this might make sense, from No. 4 on lever overhaul
Posted : 05/12/2012 8:18 pm
OK, thanks. I'm off to give it a go...
Posted : 05/12/2012 9:25 pm
