Avid Elixer 5 bite ...
[Closed] Avid Elixer 5 bite point / pad wear adjustment
Hi.
Is there any way to adjust the bite point on Avid Elixer 5's?
I've just bought a set from on-one and you have to pull the lever quite a way before the front one makes contact with the rotor. I would have thought that it would self adjust somehow as it will only get worse as the pads wear. I've not been out for a proper ride with them yet but just wondered if there was something I could do before I head out.
Thanks.
Posted : 22/03/2011 4:19 pm
Nope.. they should auto-adjust to a suitable distance from the disc.
If they are newly fitted you may have to pump the brakes a few times for them to initially adjust. Also, make sure that both pistons are being pushed out at a similar rate - if not: pump them out a bit (without pads in), smear a bit of brake fluid around the edge of the piston and then push them back in. Repeat until the move freely..
Posted : 22/03/2011 5:44 pm
Cheers. I'll give that a go.
I'll need to shorted the hoses so hopefully a bleed will help to.
Posted : 22/03/2011 9:54 pm
Was just going to say that they come with sticky pistons and a need to bleed. I'd suggest using silicone oil(Hunters, from plumbers suppliers is good) as a piston lube, working it in well by pushing the pistons in and out. Spend a good bit of time bleeding them (just when you think you've sucked all the air out, carry on and you'll probably get to suck a lot more)and you'll end up with a surprisingly good feeling brake, especially when compared to how they feel straight out of the box.
Posted : 22/03/2011 10:50 pm
