AVID CS G3 185MM RE...
[Closed] AVID CS G3 185MM REAR ROTOR ISSUES
[#795679]
Changed the rear rotor today to 185mm G3 Avid from 160mm G2 avid on my juicy seven, using of course the correct adaptor.
Cannot eliminate rubbing - tried the usual adjustment tricks loosening bolts holding the brake on while tightening / inserting business cards / pad spacer
Any ideas - is it wider than a G2?
Posted : 18/08/2009 8:21 pm
It will be wider than the used rotor it replaces. Are the pistons fully retracted before you try and set it up?
Posted : 18/08/2009 9:05 pm
Yes, pistons are fully in
Posted : 18/08/2009 9:24 pm
