I seem to recall that Assos do a range for the non-racing snakes, but not totally obvious which it is - Mille?
And is it still on the "skinny" side of normal - seen a couple of nice jackets in the sale but conscious that even without Christmas, I do not look like one of their models!
FWIW, I can just get into an L in Rapha
Mille is the slightly less agressive range. 5'11" and 73kg and wear medium if that helps.
Their sizing calculator looks really quite clever - 88kg, 5'9, says I'm an XL but the waist might be snug.
Not much left in my size,ย annoyingly....
Yep, Mille is the non racy range but like Castelli it's a bit on the tight side. I use their shorts and tights which are a comfy fit in large, the medium that their size guide recommends for me is ridiculously tight. 6' 2" 72kg 34" waist
I bought some Assos mille gt c2 in XL. The fit is great. I'm 6,4 and 100kg. Not tight on waist which is 34. They are the best bib shorts I've ever worn.
I have the Equipe RS in a small. Best shorts I've ever owned.
I'm 164cm 58kg and found the Mille a bit big in small.
I'm large in Rapha and large in Assos 187cm 78kg
