a few Qs so whats the deal then? do i need to use a WI sprocket? do i need to use a screw-on freewheel? and do they slip under heavy force? cheers
a few Qs so whats the deal then? hub is based around an eccentric axle which takes up chain slack
do i need to use a WI sprocket? yes if fixed (on newer splined versions), no if freewheeling or older double threaded version
do i need to use a screw-on freewheel? yes
and do they slip under heavy force? no
cheers
your welcome
Whats the deal then?
Allows you to take up the slack of a chain for a SS/Fixed conversion in a regular dropout frame.
Do i need to use a WI sprocket?
No - any freewheel should do.
Do i need to use a screw-on freewheel?
Yes
Do they slip under heavy force?
Can do. I used one in Ritchey dropouts. The curved profile of the dropout was not flat enough to adequately tighten up the bolts ๐
