anyone use altura a...
[Closed] anyone use altura attack 3/4 shorts , sizing question
hi not being the most athletic shape im just trying to check sizing 😉 im 5'10" and about 33" waist what size to you reckon and whats your size/shortsize
ta mick
Posted : 20/08/2009 6:35 pm
mick,
i think cyclesense have some in stock
Posted : 20/08/2009 6:52 pm
cheers mate ill take a wonder up . thanks
Posted : 20/08/2009 6:53 pm
I'm around a 29" waist and I've got plenty of room in the small size. I haven't used them on the bike yet but they were excellent for our holiday in South Wales a couple of weeks ago. I wore them over a normal pair of 3/4 trousers and still had the tabs tight. I think you can assume they are sized as overtrousers. I got mine from Merlin.
Posted : 20/08/2009 9:06 pm
Medium will be fine - I'm about a 32" waist and have them as tight as they'll go.
Posted : 20/08/2009 11:33 pm
cheers also are they any good 😉
Posted : 21/08/2009 12:25 pm
The Attacks are better than the ones they replaced (Dry Lines perhaps??) but the material isn't durable enough for wearing a lot. I've found delamination occurs relatively quickly in certain places and this is even before they've gone near a washing machine.
The previous ones wore down pretty quickly and I ended up with a hole in the rear, but Merlin were kind enough to replace them with the Attacks.
The cut is a lot better than the previous ones too, they're fine with knee pads and the material isn't too harsh when wet.
Posted : 21/08/2009 1:38 pm
just tried a pair on at the shops they only had med and it held up on the tightest setting but im thinking it may not hold up too well with bibs on they had no small to try but the lady in the shop said the smalls are very small . bugger
Posted : 21/08/2009 2:21 pm
just ordered a med set from merlin i can always put some weight on if they fall down lol i would have bought from lbs but £18 extra is a bit much to support the lbs im afraid ;-(
Posted : 21/08/2009 2:37 pm
