Yes, to me it "seems" stiffer than a normal qr spindle and in theory should be better. Its a bargain anyway!
Yes. The 9mm one appears to work. I think it is just a re-branding of the one sold under the Halo name.
Do none of them have a decent QR mechanism?
What do you mean Cynic?
Like shimano - capable of being clamped up tight easily, not plastic/brass under alloy.
clamps VERY tightly
looks same as the one supplied with the on-one 456 hub too.
I'm waiting for SSC to get the front ones back in stock as the DT Swiss one on my Stumpjumper is doing my head in. It takes loads longer than a QR to do up, ad just isn't particularly user friendly.
Might have to look on the CRC site & see if that Halo one comes in red....
I had a NC17 version of one of those. Unfortunatly the lever folded and snapped on it's first use. I went back to the RWS but they are pricey.
That said BC17 stuff seems to get good reviews so maybe I had one from a duff batch.
So could I use these with my QR Revs and Hope Pro 2 hubs? Would I need to get adaptors for the hubs?
yes hope do the nine mil bolt adaptors thats what ive got
Leku, yes if you can locate the 9mm inserts for the Pro II front hub, Hope did produce some but the run seemed limited (ask a Hope dealer). I have a specialized 9MM bolt thru QR on a Pro II front hub (with the converters), and as mentioned it "seems" stiffer.
Yeah when I said "seem" I wonder how much of it is belief, but hell for 15 quid its a bigger Bang* per buck than a Ti frame or buying new forks.
I recommend them to anyone!
*(where bang is smug feeling I've got an upgrade despite the fact that I cannot really tell if its better or not)
Guess I will find out how well it does up soon enough.... gotta be a nicer solution than the ferkin great bolt I have now, with a weird nut mech hangar type thing on the end, from a Shimano integrated system I never knew I didnt need until they made it!!!! (and I wont need my molegrips out on the trail)
Will one of these for the rear fit into the dropouts for a frame which normally takes a QR back wheel??
Apologies for my ignorance. 😳
I have a Pro2 rear hub on my shova which has QR dropouts. If I changed the adapters in the hub to take a 10mm axle will this axle fit into a conventional QR drop out on the rear of my bike??
Andylux, i've not actually tried it, bit yes apparently a 10mm bolt thru axle(qr or bolted) will work fine with the 'normal' rear dropouts
Ta Very Much z1ppy.
yeah it will ive a ten mil in mine
Andylux, be aware that the rear "adaptor" is actually a complete new axle - it's not at all like taking out a couple of front hub adaptors. Having said that it is very simple to do.
I've run one of these in the rear hub all winter. It's good and strong and does up nice and tight. It's also a cracking price although rather weighty compared to the DT Swiss (alloy) version. That's a quite acceptable trade off.
The quick release lever seems noticabley longer than the norm. Certainly, I've had no problems undoing it even after it's been cranked down heroically tight.
andylux,
It definitely works, I've a ProII running the RWS 10mm rear on my shova and its all good (been on for a few years now). The replacement axle and end caps for the proII aren't cheap though!
