Anyone running On-O...
[Closed] Anyone running On-One carbon forks with floating rotors ?
183mm Hope saw type floating rotor is rubbing on the lower bit of fork leg. (The alloy bit, not the carbon bit).
Anyone found a way round this ?
Posted : 23/01/2011 1:01 pm
Tried to once, didn't work, switched to non-floating rotors, worked fine... not much help I know ๐Ÿ™‚
Posted : 23/01/2011 1:03 pm
Yes. Sensible option I think psychle.
Posted : 23/01/2011 1:05 pm
Buy some Pace RC31's while you can. i have the same hope set up
they are good(until the magnesium cracked, whcih can be replaced). in the meantime same set up and on one scafolding pipes for forks!
Posted : 23/01/2011 4:30 pm
psychle - Member
Same here
Posted : 23/01/2011 4:51 pm
