Anyone ridden the M...
Anyone ridden the Mojo Nicolai yet?
blakec It's a guide size at either end really.
Chris' bike? The one that got temporarily built up?
At the end of the day I'm sized up. It's the standover really thats the limiting factor and how we set up bar widths. There are only 2 of these so if he rode the other one...
Posted : 13/07/2017 5:52 pm
Chainline
Sorry a bit miss leading Chris let him ride his own bike (the XL) around the carpark. It was way to big for him but he didn't want to give it back.
Posted : 13/07/2017 6:13 pm
ah, makes more sense!! I'm not convinced it's not too big for Chris! He was on the XXL. Perhaps he's gone back. I'm seeing him at the weekend so I'll check.
I thought you were on about the NotSoLong!
Posted : 13/07/2017 6:56 pm
I'm going to buy a Ion g16 frame... but I'm 5'7', so what is my correct size...S vs M?
Thanks!!
Posted : 17/07/2017 10:47 am
chastis, if you can try one first. It's a matter of personal preference.
I'd suggest the S, but you could easily set up the M to feel right. It depends on your riding style.
Posted : 17/07/2017 5:23 pm
new stuff!
https://happyride.se/2017/07/17/nicolai-eboxx-och-geometron/
All in Swedish mind
Posted : 17/07/2017 5:27 pm
chastis I'm 5'8 on a long (small) and very happy but test ride is the only way to know for sure
Posted : 17/07/2017 7:44 pm
 duir
Anyone know which bike bags a longest Geometron will fit in? I know someone mentioned the Evoc bike bag with shock removed, are there any others?
Posted : 18/07/2017 3:41 pm
My longest goes in an Evoc Pro no problem, just need air let out of the forks (180s)
Posted : 18/07/2017 3:56 pm
My XL G13 goes in the Chainreaction bag. Good bag for the money actually. Dithered about an evoc but only use it once a year and it was a fair bit more cash. This one....
http://www.chainreactioncycles.com/chain-reaction-cycles-pro-bike-bag/rp-prod114204
Posted : 18/07/2017 4:06 pm
I can fit my large g13 in an evoc bag, I have to spin the forks 180° and take the caliper off, but it fits.
Posted : 18/07/2017 4:45 pm
When your G16 longest goes back to MOJO for a remodel!
[URL= http://i935.photobucket.com/albums/ad199/Paulj3/A34F5FFC-E1CA-4B94-A415-B6D5524FC681_zpsp3llq7ln.jp g" target="_blank">http://i935.photobucket.com/albums/ad199/Paulj3/A34F5FFC-E1CA-4B94-A415-B6D5524FC681_zpsp3llq7ln.jp g"/> [/IMG][/URL]
Posted : 20/07/2017 10:43 pm
[img] http://s935.photobucket.com/user/Paulj3/media/A34F5FFC-E1CA-4B94-A415-B6D5524FC681_zpsp3llq7ln.jpg.html ][IMG] http://i935.photobucket.com/albums/ad199/Paulj3/A34F5FFC-E1CA-4B94-A415-B6D5524FC681_zpsp3llq7ln.jp g" target="_blank">http://s935.photobucket.com/user/Paulj3/media/A34F5FFC-E1CA-4B94-A415-B6D5524FC681_zpsp3llq7ln.jpg.html ][IMG] http://i935.photobucket.com/albums/ad199/Paulj3/A34F5FFC-E1CA-4B94-A415-B6D5524FC681_zpsp3llq7ln.jp g"/> [/IMG][/URL][/img]
Posted : 21/07/2017 9:30 am
doesnt seem to work Paul J?
Posted : 22/07/2017 6:24 pm
Its to do with the photobucket screw over.
Shame as there's probably a load of good photos on this thread that'll have gone.
Posted : 22/07/2017 6:28 pm
Anyone summarise day to day at 155 travel and 160 forks? On southern trails.
How about uplift days/dh tracks at 170 travel and 180mm forks?
Posted : 24/07/2017 7:08 am
Dean there are that many options now that you are best doing a demo at BPW.
Posted : 24/07/2017 10:13 am
What do you mean by summarise?
As Shandy says, it's very configurable.
I have a friend who uses one 155/160mm as a day to day down South. But to be honest 180mm front or 160mm front pedals the same and can be made to feel similar just with volume spacers. It is easy to change travel for a big trip if you buy the 180mm version first.
I also have a friend who uses the 170/180 as his everyday bike down south.
At 170mm/180mm it eats uplifts/dh and I used that for everything until I put the 160mm 29er front in, I now use 170mm/160mm as everyday and uplift bike.
Best is to try a 170/180mm bike with the right setup and decide if that suits you for everyday as the weight is the same. Just swop wheels for xc or dh.
Posted : 24/07/2017 11:39 am
So..... on XC trails, think swinley for example, will it kill any possible fun? IE, can you stand up, stomp on the pedals, pump, get to enough speed on mellower stuff to make gaps up along the way? Or are you simply stuck to sitting down twiddling and that'll be all it will ever be?
Posted : 24/07/2017 12:22 pm
I stand up and stomp and do what you describe on my 170m. Dmaping and volme spacers set up to suit. Maybe honourablegeorge can chime in here.
I love it on moderate stuff as you can carve the bejesus out of flattish corners, I leave myself breathless gathering speed 😆
I live in the midlands and ride at Cannock when not going further afield and on more local, even flatter trails. It's still great fun.
There is always the climb switch or just tweak the damping since it takes 1 min if a day on flat terrain beckons and you don't want the expense of 2 shocks.
Another alternative is to drop in a 216x63 DPS or older RP23 (other makes of shock are available) to run 155mm at the rear, have some 'trail' damping and drop 350g in weight again if Swinley or similar.
CP is 90+ kg and rides 170mm on flatter stuff too. The local tracks in Stanton are not all gnarr by any stretch and need some pedalling to get max fun.
I have just as much fun on my GeoMetron as on my old Rigid, it's just different, I've kinda moved from on the limit of the bikes traction and twitchy responses to embracing the G and high lean angles of great carves and front end grip a plenty. The feeling of a swoopy singletrack with successive opposing corners, flat or slightly bermed, driving the front round and flipping the bike side to side...lovely. Wishing I wasn't sat here at a desk typing this, I'm getting all excited about riding!
Posted : 24/07/2017 3:40 pm
I'm on 180/155 and find it a great bike - I have a hardtail I ride on flatter terrain, but when I do take the Geo on that stuff it's efficient and fun, I've never found myself wishing I wasn't on it. Don't find it at all unweidly or dull - the flat corners thing, yep, he's right on that.
I do uplift DH, regualr steeper "enduro" trails, trail riding etc, and never change settings, just jump on and ride, all I've done is set sag and use the settings Chainline kindly recommended for me, and find it just does it all. Tried Shockwiz, and changed nothing but a click of LSC.
I rode a 160/160 26er Nicolai Ion 16 previously, and the 180/155 Geometron doesn't feel less fun or playful in any way
Posted : 24/07/2017 4:10 pm
Personal preference and only you can answer imo. I have a G13 which I think is a great bike, really enjoy riding it and I'm constantly amazed by what I can do on it. That said I also have a new Chameleon with plus tyres and a 130mm fork. I come from the 'knife to a gunfight' bike approach so I am naturally biased against Chainline's view but there are some trails in Surrey Hills which are just a lot more fun, for me, on the Chameleon. The Nicolai feels dull by comparison, like I'm arm wrestling it into doing something that it can do perfectly well but at the same time, it doesn't really want to do. It wants to go fast over rougher terrain whilst being smashed into corners at every chance, not hussle along a trail which points vaguely downhill where the biggest tech challenge are some roots that are tentatively breaking through the surface. The Chameleon on the same milder trails actively encourages you to ride like a kid again, attempting your best Voreis style on trail manuals and popping off tiny roots etc. I think it comes down to weight difference, the increase in get up and go on pedal input that you get from hardtail/shorter travel bike and that feeling of the bike getting unsettled from roots etc in the trail. Anyway, my tuppence.
Posted : 24/07/2017 4:20 pm
Gotama - Member
*points at 29er wheels*
*taps nose*
Posted : 24/07/2017 4:55 pm
😀 Pffft, it does still go round corners which is a source of constant amazement. 😀
Posted : 24/07/2017 5:02 pm
I'd have a g13 given half a chance. There was one second hand in the classifieds that gave me serious pause for thought/divorce
Posted : 24/07/2017 5:03 pm
I think Gotama sums it up, personally as mentioned (with bad typing) I find it more fun than my old short travel and/or rigid bikes not less but it depends what you like doing.
I went out not so long ago on my Stooge and was seriously underwhelmed as I just couldn't drive it into corners in the same way.
Each to their own. The way to determine if it's too dull for you is give it a go 😉
Posted : 24/07/2017 5:53 pm
There be a few stock G13's available at Mojo young Paul tells me, across all sizes.
If anyone is interested get in touch direct. I gather there are deals to be done.
Posted : 26/07/2017 8:10 pm
Why is that Phil, are they being phased out?
Still like to try a G13 in longer!!
Regards
H
Posted : 27/07/2017 12:52 pm
Any g16 deals to be done?
Posted : 27/07/2017 12:55 pm
CatVet, no not to my knowledge. More people have been buying G16s recently. Mojo carry stock and only have so much space not taken up by suspension which probably neatly answers Julian's question....
There have been more 'long travel' releases from the mainstream this year in 29er whereas last year it seemed to be 'shorter travel'
That
Posted : 27/07/2017 5:49 pm
I really wish I hadn't read that ...
Posted : 27/07/2017 6:38 pm
You want the G16 mate. 8)
There's another one appearing in our garage soon. 😀
Posted : 27/07/2017 9:00 pm
I loves my 16 I must confess. The fact Singlespeedstu feels that way enough to go 2x makes me very happy indeed
Posted : 27/07/2017 10:03 pm
It's not for me, that'd just be greedy.
Mrs stus has been bitten by the Geometron bug. 😆
I did warn her not to try one unless she wanted to buy a new bike...
Posted : 27/07/2017 10:19 pm
Thought that might be the case. That up's the stoke further
Posted : 27/07/2017 10:49 pm
Hey chainline, just seen geometron's post on insta. What's the info on the custom shock for the g13?
Posted : 28/07/2017 9:59 pm
I was gonna post on here. Can't link pics via Flickr via phone!
Headline is Chris/Paul have developed a custom length DHX-2 coil for the G13 to deliver 148mm of rear travel to match a 150mm front (or less of course if you choose up front)
They'll show it at Ard Rock, there will be a demo bike there.
I'll probably get hold of one to fit to mine for demo purposes.
It is of course retro-fittable and can be combined with the potential deals on the current G13 frames.
Posted : 29/07/2017 10:04 am
Any details on the shock? Is it still 190 length with just a longer stroke?
Posted : 29/07/2017 10:10 am
Longer stroke, 190mm length.
Posted : 29/07/2017 12:17 pm
For those wondering; longer travel G13 with custom DHX-2, 148mm rear travel.
[img][url= https://farm5.staticflickr.com/4304/35404822294_ea56967905_b.jp g" target="_blank">https://farm5.staticflickr.com/4304/35404822294_ea56967905_b.jp g"/> [/img][/url][url= https://flic.kr/p/VWAYbA ]IMG_1082[/url] by [url= https://www.flickr.com/photos/the_pilot/ ]Phil[/url], on Flickr[/img]
Posted : 29/07/2017 12:18 pm
oooh. It's built. For those who've been in touch I'll be in touch.
For the record H is 5'2" or 158cm tall. Bang in the middle of the size range.
The bike is built with a 160mm fork, 145mm rear (158mm with a different shock) and comfortably fits a 150mm dropper for H's height. It fits great and gets a big thumbs up from the carpark test!
Weight is a genuine 13.2kg/29lbs. with 2.35 Magic Mary and 2.35 Maxxis Aggressor EXO.
[img][url= https://farm5.staticflickr.com/4299/35456800833_6791fbb07d_b.jp g" target="_blank">https://farm5.staticflickr.com/4299/35456800833_6791fbb07d_b.jp g"/> [/img][/url][url= https://flic.kr/p/W2cnAi ]IMG_1084[/url] by [url= https://www.flickr.com/photos/the_pilot/ ]Phil[/url], on Flickr[/img]
[img][url= https://farm5.staticflickr.com/4312/35456805853_11e6f04d73_b.jp g" target="_blank">https://farm5.staticflickr.com/4312/35456805853_11e6f04d73_b.jp g"/> [/img][/url][url= https://flic.kr/p/W2cp5R ]IMG_1088[/url] by [url= https://www.flickr.com/photos/the_pilot/ ]Phil[/url], on Flickr[/img]
[img][url= https://farm5.staticflickr.com/4307/35456804503_296507647d_b.jp g" target="_blank">https://farm5.staticflickr.com/4307/35456804503_296507647d_b.jp g"/> [/img][/url][url= https://flic.kr/p/W2coFz ]IMG_1087[/url] by [url= https://www.flickr.com/photos/the_pilot/ ]Phil[/url], on Flickr[/img]
Posted : 30/07/2017 1:15 pm
Owww look at the ickle Geometron it looks so cute.
I'll have to show these pics to my mates youngest.
She'll love it.
Posted : 30/07/2017 4:55 pm
Thats really nice!
Posted : 30/07/2017 5:47 pm
 ART
Nice! Thanks for the msg too 🙂
Posted : 30/07/2017 6:33 pm
Literially, just got the G16 built up since coming back from Mojo and had a day at FOD. Between paul and chris they have manage to do what I was asking for.
So the G16 is now equipped with 29er wheels front an back, 180mm 27.5 CSU with 29er lowers. 450mm swing arm but still running the original x2 at 150mm
2016 G16 Longest
Head angle 62 degree
seat angle 76 degree
BB 347MM
29er front and back
Its an amazing bike, I've had the G16 29er/27 rear set up and loved that. But wanted to give it ago 29er front and back. I've enjoyed all three set ups on the one bike. Something i didn't think I'd ever own one frame that could accommodate so much tinkering.
Bit of a trigger/del boy broom set up you could say.
Posted : 30/07/2017 6:39 pm
Page 30 / 48
