I was given a Rockshox reba fork, so can't really complain but the steerer is too short to put my current stem on. Anyone know of a 1 1/8th stem(25.4) with a steerer clamp shorter that 38mm? Cheers.
Check out FSA...some of their stems are 35mm
I've got a Truvativ one thats < 35mm - 110 (or a 100) with 5 degree rise I think. £10 posted?
Spank make an ultra-low stack stem.
If it's 100 and 25.4 clamp i'm tempted. Cheers.
I'll have a check.
Cheers.
It's a 110, sorry - stack height is 36mm too - thought it was a bit less.
Sorry, a bit longer than i was looking for. Thanks anyway.
Pro FRS is 35mm, looks good, strong and light. I don't have one to sell you, but can highly recommend it.
Remember that you need a few mm of slack in your stack height so you can tension the Headset without the top-cap hitting the top of the steerer. I'd be happy to have a 5mm gap when you fit the stem, which would give you a bit more to play with.
Alternatively, a Crank Brothers Cobalt Headset will give you more height to play with still, assuming you have a normal headset.
If you're after a shorty stem I have a 40mm white Funn with a black faceplate - stack height is a tiny 32mm. You can see it on my old [url= http://mamadirt.fotopic.net/p65752491.html ]Flow Myth[/url]. Only used for a few months (tiny paint chip above steerer clamp bolt) - £20 posted?
Pro FRS is 40mm according to this:
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=44971
Truvativ XR are 35mm ish, some FSAs similar. Kore Race is 40mm but has a single bolt fixing which is good for short steerer.
Had a similar problem, got a
Dangerboy AK47 in 25.4
which is 30mm stack if I remember rightly
Need 90 i think mamadirt, cheers anyway.
As long as it's a single bolt on the steerer bolt sambob you should be ok so long as the bolt sits below the top of the steerer. Sunline stems are quite low too.
You got any examples slowrider? gonna nab my dads crossbike stem for now i think 😛
