Anyone got a link t...
[Closed] Anyone got a link to Scandal MK2 geo/spec etc?
[#9468189]
Thanks guys!
What is hub spacing by the way? 🙂
Posted : 31/07/2017 8:42 pm
Qr 135 rear
Posted : 31/07/2017 8:54 pm
Thanks mate,
9mm,qr. Not 10mm weirdness? 😉
Posted : 31/07/2017 8:58 pm
Scandal 29er
M/17.5" L/19"
Head Angle (degrees) 69.5 69.5
Head Tube (mm) 105 115
Top Tube C-C Effective(mm) 600 620
Seat Tube Angle (degrees) 72.5 72.5
Seat Tube C-T (mm) 440 490
Chainstays (mm) 440 440
BB Drop (mm) 60 60
Stack (mm) 618 627
Reach (mm) 405 422
Front Centre (mm) 645 685
Fork Length (mm) 506 506
Offset (mm) 45 45
Wheelbase (mm) 1097 1118
Posted : 31/07/2017 9:00 pm
Sorry - can't seem to format the post...
Hope it's useful (assuming you can pick the bones out of that)
Rich
Posted : 31/07/2017 9:02 pm
Posted : 31/07/2017 9:07 pm
And I think this is V1...
Posted : 31/07/2017 9:08 pm
Hmmm, contradictory info, worse than no info!
Posted : 31/07/2017 9:13 pm
Wow, thanks guys!
So a MK2 20" frame, how would that be for a 6' rider, right sort of ball park?
 bubs
Probably not very useful to you, but a 19.5" mk1frame is probably one of the best fitting frames I have had at 6ft 2. Short stem and you should be good (but may be not as chuckable as something like a cotic which have always felt small to me).
Posted : 31/07/2017 9:28 pm
Depends how small you like your bikes.
I'm 6'3" and i've got both 19.5 (v1) and 21 (v2). They're both ace.
You might get away with an 18".
Posted : 31/07/2017 9:32 pm
RichBowman those head angles look all wrong? I'm sure it's 71/72 degrees?
Posted : 31/07/2017 9:49 pm
it depends on whether you are long in leg or body, there's only 20mm difference in the ETT ("C")
Posted : 31/07/2017 10:56 pm
Hmmmm... the 444 chain stays ring a bell. Am sure those numbers are from the On One website - but that’s no guarantee of provenance... 😆
Maybe try the old trick... Brant, Brant, Brant....
FWIW - I’m just over 6ft, and found the large to be a bit of a gate, but the 18 (M) too small (on the V2). A shorter stem might have helped the L to be honest.
Cheers,
Rich
Posted : 31/07/2017 10:58 pm
Poopscoop - Member
Wow, thanks guys!
I'm half an inch shorter but it sounds like you have same issue I often find. The caught between to sizes curse!
I have 2 29er hardtails. One slightly too small. The fits great but probably looks slightly too big. It's the goldilocks syndrome. 😆
Posted : 01/08/2017 12:27 pm
