Not sure if its possible as its an 1 1/8th semi intergrated head tube......
Any one tried and succeeded/failed??
Semi-integrated so 44mm internal diameter?
There are certainly angle headsets that will fit that - although you might end up with an external top cup, eg:
The superstar one also looks to have a stuiable fit option:
https://www.superstarcomponents.com/en/slackerizer-angle-headset.htm
Best bet is to knock the current one out and measure up
Yeah I've just been looking at those and couldn't work out if they would work. If the only difference is that it'd be an external cup I don't mind about that.
Will get the old one out and have a look.
Been thinking about this for my daughter's blast.
Would be interested to know which one fits.
Why? is she complaining of lack of stability at high speed a lot?
Not really any need for sarcasm is there.
I just think it might give my lad a bit more confidence on the downs. Especially in the alps.
^^ Not sure there is any sarcasm there. ย Look like serious responses. ย 👍🏼
I wasn't being sarcastic.
Ok, have you got ahy thoughts on whether an angleset will fit the bike then?
